CodeWarrior® TAP without CodeWarrior software?
miha_at_work
Hello.
Is there some way to use CodeWarrior TAP for debugging device based on LS2084 using only open source or low cost software. CodeWarrior is very expensive for us.
miha_at_work
So how about GDB?
ufedor
CodeWarrior TAP supports network port 2345 used by GDB to control the TAP.
miha_at_work
Is TAP compatible with GDB? Will it stable work with GDB?
ufedor
The GDB is not an NXP product and it is not officially supported.
Please use NXP Community to find additional information.
miha_at_work
Ok. Thank you.
ufedor
Please check tools from other vendors: Lauterbach, Wind River, Green Hills.
