Cannot set CONFIG_DDR_NODIMM
1,917件の閲覧回数
bezeria
I am using latest flexbuild from https://github.com/NXP/flexbuild
I am modifying `flexbuild/components_lsdk2512/bsp/atf/plat/nxp/soc-lx2160a/lx2160ardb/platform.mk`
to include `CONFIG_DDR_NODIMM := 1`
Afterwards, I am rebuilding atf with `bld atf -m lx2160ardb -b sd` , but I am getting the following error:
Building ATF for lx2160ardb sd boot
cp: cannot stat 'build/lx2160ardb/release/bl2_sd*.pbl': No such file or directory
make[1]: *** [/home/bezeria/repos/flexbuild/src/bsp/atf.mk:107: atf] Error 1
make: *** [Makefile:14: atf] Error 2
4 返答(返信)
1,819件の閲覧回数
bezeria
I managed to fix the MCLK cycle problem, but I arrived to a new problem of interleaving mode. I am using the default 2 ddr controllers NUM_OF_DDRC . The error is:
NOTICE: BL2: Built : 23:02:58, Feb 28 2026
NOTICE: Fixed DDR Config 1
ERROR: Unknown interleaving modeERROR: Assigning address error
This happens with 2 or 4 DIMM configuration (info.dimm_on_ctlr = DDRC_NUM_DIMM  = 2 or 4)
1,823件の閲覧回数
bezeria
One problem is fixed when I updated the ddr_get_ddr_params in ddr_init.c
The atf compiles now succesfully, but when I deploy it, I get
NOTICE: BL2: Built : 18:50:19, Feb 28 2026
ERROR: DDR Clk: MCLK cycle is 625 ps.
ERROR: DDR Clk is faster than DIMM can support.
ERROR: Execution FW failed (error code -5)
ERROR: Calculating DDR PHY registers failed.
The DIMM I am deploying is 2933Mhz (lower than the default 3200Mhz); I have already edited the RCW to lower the DDR controller to 2900 and even 2600. The error still happens.
How can I correctly configure the DDR clock?
1,883件の閲覧回数
LFGP
Dear @bezeria ,
The LX2160 platform doesn't have support for NODIMM out of the box.
you need to add  your DDR_NODIMM_Custom file to ATF.
Please use the DDRv tool to obtain the ddr_init.c acoording to your needs, then add it to the ATF.
LFGP
1,873件の閲覧回数
bezeria
I have the values for CONFIG_DDR_NODIMM for the ATF.
I place them to ddr_init.c then place CONFIG_DDR_NODIMM:=1 to platform.mk, and issue
bld bsp -m lx2160ardb
But I get the error described in the previous post.
%3CLINGO-SUB%20id%3D%22lingo-sub-2322628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECONFIG_DDR_NODIMM%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fflexbuild%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fflexbuild%3C%2FA%3E%E3%81%8B%E3%82%89%E6%9C%80%E6%96%B0%E3%81%AE%20flexbuild%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%60flexbuild%2Fcomponents_lsdk2512%2Fbsp%2Fatf%2Fplat%2Fnxp%2Fsoc-lx2160a%2Flx2160ardb%2Fplatform.mk%60%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%60CONFIG_DDR_NODIMM%20%3A%3D%201%60%20%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%20%60bld%20atf%20-m%20lx2160ardb%20-b%20sd%60%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20atf%20%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Elx2160ardb%20sd%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AEATF%E3%81%AE%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%3CBR%20%2F%3Ecp%3A%20'build%2Flx2160ardb%2Frelease%2Fbl2_sd*.pbl'%20%E3%82%92%20stat%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%5B1%5D%3A%20***%20%5B%2Fhome%2Fbezeria%2Frepos%2Fflexbuild%2Fsrc%2Fbsp%2Fatf.mk%3A107%3Aatf%5D%20%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20make%3A%20***%20%5BMakefile%3A14%3A%20atf%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2323909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Cannot%20set%20CONFIG_DDR_NODIMM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2323909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256728%22%20target%3D%22_blank%22%3E%40bezeria%3C%2FA%3E%E6%A7%98%3C%2FP%3E%0A%3CP%3ELX2160%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AF%E3%80%81%E6%A8%99%E6%BA%96%E3%81%A7%E3%81%AF%20NODIMM%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EDDR_NODIMM_Custom%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20ATF%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EDDRv%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6ddr_init.c%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81ATF%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3ELFGP%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2323925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Cannot%20set%20CONFIG_DDR_NODIMM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2323925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EATF%20%E3%81%AE%20CONFIG_DDR_NODIMM%20%E3%81%AE%E5%80%A4%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%82%92ddr_init.c%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%E6%AC%A1%E3%81%AB%E3%80%81platform.mk%E3%81%ABCONFIG_DDR_NODIMM%3A%3D1%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%3C%2FP%3E%3CP%3Ebld%20bsp%20-m%20lx2160ardb%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%89%8D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Cannot%20set%20CONFIG_DDR_NODIMM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMCLK%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AA%E3%83%BC%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E3%81%84%E3%81%86%E6%96%B0%E3%81%9F%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%202%20DDR%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20NUM_OF_DDRC%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%E9%80%9A%E7%9F%A5%3A%20BL2%3A%20%E6%A7%8B%E7%AF%89%E6%97%A5%E6%99%82%3A%202026%E5%B9%B42%E6%9C%8828%E6%97%A5%2023%3A02%3A58%3CBR%20%2F%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%3A%20DDR%20Config%201%20%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AA%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF2%E6%9E%9A%E3%81%BE%E3%81%9F%E3%81%AF4%E6%9E%9A%E3%81%AEDIMM%E6%A7%8B%E6%88%90%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88info.dimm_on_ctlr%3D%20DDRC_NUM_DIMM%20%3D%202%20%E3%81%BE%E3%81%9F%E3%81%AF%204)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Cannot%20set%20CONFIG_DDR_NODIMM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eddr_init.c%20%E3%81%AE%20ddr_get_ddr_params%20%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%811%20%E3%81%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EATF%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E3%81%A8%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%E9%80%9A%E7%9F%A5%3A%20BL2%3A%20%E6%A7%8B%E7%AF%89%E6%97%A5%E6%99%82%3A%202026%E5%B9%B42%E6%9C%8828%E6%97%A5%2018%3A50%3A19%3CBR%20%2F%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%3A%20DDR%20Config%201%20%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20DDR%20Clk%3A%20MCLK%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AF%20625%20ps%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20DDR%20Clk%20%E3%81%AF%20DIMM%20%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E9%80%9F%E5%BA%A6%E3%82%88%E3%82%8A%E3%82%82%E9%80%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20FW%20%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%20-5)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20DDR%20PHY%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%A8%88%E7%AE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E7%A7%81%E3%81%8C%E5%B0%8E%E5%85%A5%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20DIMM%20%E3%81%AF%202933Mhz%20(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%203200Mhz%20%E3%82%88%E3%82%8A%E4%BD%8E%E3%81%84)%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%99%E3%81%A7%E3%81%AB%20RCW%20%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%A6%E3%80%81DDR%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%202900%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%81%AF%202600%20%E3%81%AB%E4%B8%8B%E3%81%92%E3%81%A6%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDDR%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
