Building the default bootloader files for the LS1046ARDB from within CodeWarrior
Daves_Garage
Is there a "how to" guide for building the bootloader firmware for the LS1046ARDB from within Codewarrior and flashing it?  An appnote perhaps?  I can't seem to find anything.
Thanks in advance.
Hector_Villarruel
Hello, Thank you for contacting the Technical Support Team,
I hope that this email finds you well,
In the following link you can find the Application Note AN12081 "RAM Boot using CodeWarrior on LS1046ARDB", where at section 5 you can find the booting process with an SD Card.
Hector Villarruel
Daves_Garage
Thank you Sir!
Hector_Villarruel
Hector Villarruel
