Building linux kernal with flex-builder
nagurvalisayyad
   We are using LS1046ardb kit in dpdk mode. Now we want to change the usdpaa dts file to bring few of the ethernet ports to linux. We have done the changes in fsl-ls1046a-rdb-usdpaa.dts file. We are facing the compilation issues to generate the binary files.
The following are the sequence of commands executed:
1) export CROSS_COMPILE = aarch64-linux-gnu-
    export ARCH=arm64
2) flex-builder -c linux
3) flex-builder -i mkitb -r ubuntu:main
4) flex-builder -i mklinux -r ubuntu
5) flex-builder -i mkbootpartition
6) flex-builder -i mkrfs
7) flex-builder -i merge-component
flex-builder -i packrfs
While executing the above commands, at the 5th command of mkbootpartition, we are getting the error of "Error in opening the file: pfe.itb" and exits.
Please guide us in solving the above error or if some other method is there to change the dts and incorporate those changes in the target board.
Thanks--
Nagurvali Sayyad.
Please guide us in correcti
yipingwang
1. $ source setup.env
2. $ flex-builder -c linux
Go to folder flexbuild_lsdk2108/components/linux/linux, modify dpdk dts file arch/arm64/boot/dts/freescale/fsl-ls1046a-rdb-usdpaa.dts.
3. $ flex-builder -c linux
4. $ flex-builder -i mkbootpartition
If your problem remains, please provide your build console log.
yipingwang
