Build problem LSDK19.09 for LS-1046AFRWY.
takayuki_ishii
Contributor V
Hello community,
I try to build all image automatically for LS-1046AFRWY by following command.
> flex-builder -m ls1046afrwy
But, building apps/FMC will stop by link error as following mesage.
arch64-linux-gnu-g++ -L/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/apps/components_LS_arm64_ubuntu/lib -L/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/lib -L/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/lib/aarch64-linux-gnu -L/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib -Wl,-rpath=/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/lib:/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/lib/aarch64-linux-gnu:/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib:/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu -L. -L/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/apps/components_LS_arm64_ubuntu/lib -o fmc FMC.o FMCUtils.o FMCGenericError.o libfmc.a -lfmc -lfm -lxml2 -lm
//home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicuuc.so.60: undefined reference to `icudt60_dat'
collect2: error: ld returned 1 exit status
Makefile:127: recipe for target 'fmc' failed
make[2]: *** [fmc] Error 1
make[2]: Leaving directory '/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/packages/apps/fmc/source'
Makefile:169: recipe for target 'fmc' failed
make[1]: *** [fmc] Error 2
make[1]: Leaving directory '/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019/packages/apps'
Makefile:28: recipe for target 'apps' failed
make: *** [apps] Error 2
make: Leaving directory '/home/evmuser/ls1046a/flexbuild_lsdk1909_update_221019'
It seems that pre-build library image of libicuuc.so have undefined reference.
So I hope to update this library.
Do I have to method to build pre-build rootfs library?
i.e. modify default FETCH_PREBUILT_LSDK_RFS=y to n in <flexbuild-dir>/configs/build_lsdk.cfg.
If you have some other method, please let me know.
Ishii.
Tags (2)
yipingwang
Hello Takayuki Ishii ,
Please check whether flexbuild_lsdk1909_update_221019/build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu\libicudata.so exists in your build environment.
Please make sure there is no networking connection problem.
You could run the following commands to download rootfs again.
$ flex-builder -i mkrfs  -a arm64 -i clean-rfs
TIC
takayuki_ishii
Contributor V
Hello Yiping Wang,
Thank you for your quick response.
"libicudata.so" can find  in your specified directory.
I will try the command to reload rootfs because it may be broken.
Ishii.
evmuser@evmhost18:~/ls1046a/flexbuild_lsdk1909_update_221019$ find . -name libicu* -print 2> /dev/null
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libiculx.so.60.2
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicuuc.a
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicutest.so.60.2
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicuio.so.60
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicutu.so
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicuio.a
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicudata.so
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicudata.so.60.2
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicui18n.so
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicu-le-hb.a
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicu-le-hb.so
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicuuc.so.60
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicu-le-hb.so.0
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libiculx.a
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicui18n.so.60
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicutu.so.60.2
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicu-le-hb.so.0.0.0
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicudata.a
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicui18n.so.60.2
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicuio.so.60.2
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicui18n.a
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicutu.a
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicuuc.so.60.2
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/lib/aarch64-linux-gnu/libicutest.a
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/share/lintian/overrides/libicu60
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/share/doc/libicu-dev
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/share/doc/libicu-le-hb-dev
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/share/doc/libiculx60
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/share/doc/libicu60
./build/rfs/rootfs_lsdk1909_LS_arm64_main/usr/share/doc/libicu-le-hb0
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu-le-hb-dev:arm64.list
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu-dev.md5sums
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu-le-hb0:arm64.md5sums
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu-le-hb0:arm64.triggers
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu60:arm64.triggers
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libiculx60:arm64.shlibs
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libiculx60:arm64.list
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu60:arm64.shlibs
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libiculx60:arm64.md5sums
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu60:arm64.list
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu-le-hb0:arm64.shlibs
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu-le-hb-dev:arm64.md5sums
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu-dev.list
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu60:arm64.md5sums
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libiculx60:arm64.triggers
./build/rfs/rootfs_lsdk1909_LS_arm64_main/var/lib/dpkg/info/libicu-le-hb0:arm64.list
