2160 kexec problem
2160 kexec problem
1,643件の閲覧回数
lucienofliu
    I am working on 2160 processor to use kexec to jump into a new kenel, but after "kexec -e", the board haltled, like this:
# /usr/kexec -e
[ 93.742151] kexec_core: Starting new kernel
[ 93.746328] Disabling non-boot CPUs ...
[ 93.804342] IRQ 136: no longer affine to CPU1
[ 93.804408] CPU1: shutdown
[ 93.811460] psci: CPU1 killed.
[ 93.836301] IRQ 137: no longer affine to CPU2
[ 93.836347] CPU2: shutdown
[ 93.843387] psci: CPU2 killed.
[ 93.876308] IRQ 138: no longer affine to CPU3
[ 93.876337] CPU3: shutdown
[ 93.883378] psci: CPU3 killed.
[ 93.916273] IRQ 139: no longer affine to CPU4
[ 93.916316] CPU4: shutdown
[ 93.923356] psci: CPU4 killed.
[ 93.964293] IRQ 140: no longer affine to CPU5
[ 93.964328] CPU5: shutdown
[ 93.971367] psci: CPU5 killed.
[ 94.008262] IRQ 141: no longer affine to CPU6
[ 94.008305] CPU6: shutdown
[ 94.015345] psci: CPU6 killed.
[ 94.044271] IRQ 142: no longer affine to CPU7
[ 94.044303] CPU7: shutdown
[ 94.051343] psci: CPU7 killed.
[ 94.096257] IRQ 143: no longer affine to CPU8
[ 94.096302] CPU8: shutdown
[ 94.103342] psci: CPU8 killed.
[ 94.144255] IRQ 144: no longer affine to CPU9
[ 94.144286] CPU9: shutdown
[ 94.151325] psci: CPU9 killed.
[ 94.200237] IRQ 145: no longer affine to CPU10
[ 94.200293] CPU10: shutdown
[ 94.207506] psci: CPU10 killed.
[ 94.248282] CPU11: shutdown
[ 94.251065] psci: CPU11 killed.
[ 94.308281] CPU12: shutdown
[ 94.311065] psci: CPU12 killed.
[ 94.344271] CPU13: shutdown
[ 94.347054] psci: CPU13 killed.
[ 94.380258] CPU14: shutdown
[ 94.383042] psci: CPU14 killed.
[ 94.400252] CPU15: shutdown
[ 94.403035] psci: CPU15 killed.
[ 94.417654] Bye!
Then the console has no output, After reading kexec code, I got some question:
1. Does 2160 processor support VHE? I got message from 2160 datasheet that the core support all ARMv8 feature, but the value of register id_aa64mmfr1_el1 is 0.
2. Should I configure CONFIG_KVM to reconfigure the interrupt vector table? The function el2_setup has configure the el1_sync.
    Thanks!
1,601件の閲覧回数
yipingwang
Do you use LSDK 21.08?
In previous LSDK, The second kernel with kexec cannot boot up on LX2160A, this issue is fixed in LSDK 21.08.
You need to install kexec-tools 2.0.21 in Ubuntu 20.04.
Please refer to section "7.3 kdump/kexec User Manual" in LSDKUG_Rev21.08.pdf for details.
