The patch to support DDR3L in LS1043A
The attached patch is to support DDR3L in LS1043A.
The SDK version is Linux-LS1043A-SDK-V0.5-SOURCE-20151223-yocto.iso. Not SDK2.0.
The DDR3L part number is two Winbond W632GU6KB(16M x 8 banks x 16 bits DDR3L SDRAM).
标记 (2)
附件
评论
It looks like that part of your patch code is not needed. NXP SDK 2.0 include/configs/ls1043ardb.h file contains the following:
#include "ls1043a_common.h"
This file contains the following:
#ifndef CONFIG_SYS_FSL_DDR4
#define CONFIG_SYS_FSL_DDR3                              /* Use DDR3 memory */
#endif
#define CONFIG_VERY_BIG_RAM
#define CONFIG_SYS_DDR_SDRAM_BASE          0x80000000
#define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY      0
#define CONFIG_SYS_SDRAM_BASE                      CONFIG_SYS_DDR_SDRAM_BASE
#define CONFIG_SYS_DDR_BLOCK2_BASE 0x880000000ULL
Pavel Chubakov
You still need to add DDR3 raw timing parameters and DDR3 ODT definition in u-boot.
SDK2.0 doesn't has these code.
Wes
Hi All,
hi im new to this platform QorIQ LS1043a so please send me the SDK link and how to install it.
Raghavendra
%3CLINGO-SUB%20id%3D%22lingo-sub-1122028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8LS1043A%E4%B8%AD%E6%94%AF%E6%8C%81DDR3L%E7%9A%84%E8%A1%A5%E4%B8%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%89%80%E9%99%84%E8%A1%A5%E4%B8%81%E7%94%A8%E4%BA%8E%E6%94%AF%E6%8C%81%20LS1043A%20%E4%B8%AD%E7%9A%84%20DDR3L%E3%80%82%3C%2FP%3E%3CP%3ESDK%E7%89%88%E6%9C%AC%E4%B8%BALinux-LS1043A-SDK-V0.5-SOURCE-20151223-yocto.iso%E3%80%82%E4%B8%8D%E6%98%AFSDK2.0%E3%80%82%3C%2FP%3E%3CP%3EDDR3L%20%E9%83%A8%E4%BB%B6%E7%BC%96%E5%8F%B7%E4%B8%BA%E4%B8%A4%E4%B8%AA%20Winbond%20W632GU6KB%EF%BC%8816M%20x%208%20%E7%BB%84%20x%2016%20%E4%BD%8D%20DDR3L%20SDRAM%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1122028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%89%80%E9%99%84%E8%A1%A5%E4%B8%81%E7%94%A8%E4%BA%8E%E6%94%AF%E6%8C%81%20LS1043A%20%E4%B8%AD%E7%9A%84%20DDR3L%E3%80%82%3C%2FP%3E%3CP%3ESDK%E7%89%88%E6%9C%AC%E4%B8%BALinux-LS1043A-SDK-V0.5-SOURCE-20151223-yocto.iso%E3%80%82%E4%B8%8D%E6%98%AFSDK2.0%E3%80%82%3C%2FP%3E%3CP%3EDDR3L%20%E9%83%A8%E4%BB%B6%E7%BC%96%E5%8F%B7%E4%B8%BA%E4%B8%A4%E4%B8%AA%20Winbond%20W632GU6KB%EF%BC%8816M%20x%208%20%E7%BB%84%20x%2016%20%E4%BD%8D%20DDR3L%20SDRAM%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E8%AE%BE%E5%A4%87%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALS1043A%E4%B8%AD%E6%94%AF%E6%8C%81DDR3L%E7%9A%84%E8%A1%A5%E4%B8%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E4%BB%8D%E7%84%B6%E9%9C%80%E8%A6%81%E5%9C%A8%20u-boot%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%20DDR3%20%E5%8E%9F%E5%A7%8B%E6%97%B6%E5%BA%8F%E5%8F%82%E6%95%B0%E5%92%8C%20DDR3%20ODT%20%E5%AE%9A%E4%B9%89%E3%80%82%3C%2FP%3E%3CP%3ESDK2.0%E6%B2%A1%E6%9C%89%E8%BF%99%E4%BA%9B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%9F%A6%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎07-10-2016 09:45 PM
更新人:
