The patch to support Aquantia AQR107 in LS1043A
The attached patch is to support Aquantia AQR107 in LS1043A.
Comments
Does any support for Aquantia AQR108 in LS1043A ?
Should be add below patch, but I don't know AQR108's device id.
Need to check spec.
+struct phy_driver aqr108_driver = {
+ .name = "Aquantia AQR108",
+ .uid = 0x3a1????,  <- Need to check spec
+ .mask = 0xfffffff0,
+ .features = PHY_10G_FEATURES,
+ .mmds = (MDIO_MMD_PMAPMD | MDIO_MMD_PCS|
+   MDIO_MMD_PHYXS | MDIO_MMD_AN |
+   MDIO_MMD_VEND1),
+ .config = &aquantia_config,
+ .startup = &aquantia_startup,
+ .shutdown = &gen10g_shutdown,
 int phy_aquantia_init(void)
  phy_register(&aq1202_driver);
  phy_register(&aq2104_driver);
  phy_register(&aqr105_driver);
+ phy_register(&aqr108_driver);
  return 0;
Thanks a lot! We have the datasheet of AQC108 ethernet controll with PCI express. Unfortunately, we can't find out any information about the .uid. Any keyword we can use to know the correct uid ?
%3CLINGO-SUB%20id%3D%22lingo-sub-1101949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThe%20patch%20to%20support%20Aquantia%20AQR107%20in%20LS1043A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20attached%20patch%20is%20to%20support%20Aquantia%20AQR107%20in%20LS1043A.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1101949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20attached%20patch%20is%20to%20support%20Aquantia%20AQR107%20in%20LS1043A.%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1101949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%20Devices%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20The%20patch%20to%20support%20Aquantia%20AQR107%20in%20LS1043A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20a%20lot!%20We%20have%20the%20datasheet%20of%20AQC108%20ethernet%20controll%20with%20PCI%20express.%20Unfortunately%2C%20we%20can't%20find%20out%20any%20information%20about%20the%20.uid.%20Any%20keyword%20we%20can%20use%20to%20know%20the%20correct%20uid%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20The%20patch%20to%20support%20Aquantia%20AQR107%20in%20LS1043A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EShould%20be%20add%20below%20patch%2C%20but%20I%20don't%20know%20AQR108's%20device%20id.%3C%2FP%3E%3CP%3ENeed%20to%20check%20spec.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B%3CBR%20%2F%3E%2Bstruct%20phy_driver%20aqr108_driver%20%3D%20%7B%3CBR%20%2F%3E%2B%26nbsp%3B.name%20%3D%20%22Aquantia%20AQR108%22%2C%3CBR%20%2F%3E%3CSTRONG%3E%2B%26nbsp%3B.uid%20%3D%200x3a1%3F%3F%3F%3F%2C%26nbsp%3B%20%26lt%3B-%20Need%20to%20check%20spec%3C%2FSTRONG%3E%3CBR%20%2F%3E%2B%26nbsp%3B.mask%20%3D%200xfffffff0%2C%3CBR%20%2F%3E%2B%26nbsp%3B.features%20%3D%20PHY_10G_FEATURES%2C%3CBR%20%2F%3E%2B%26nbsp%3B.mmds%20%3D%20(MDIO_MMD_PMAPMD%20%7C%20MDIO_MMD_PCS%7C%3CBR%20%2F%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3BMDIO_MMD_PHYXS%20%7C%20MDIO_MMD_AN%20%7C%3CBR%20%2F%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3BMDIO_MMD_VEND1)%2C%3CBR%20%2F%3E%2B%26nbsp%3B.config%20%3D%20%26amp%3Baquantia_config%2C%3CBR%20%2F%3E%2B%26nbsp%3B.startup%20%3D%20%26amp%3Baquantia_startup%2C%3CBR%20%2F%3E%2B%26nbsp%3B.shutdown%20%3D%20%26amp%3Bgen10g_shutdown%2C%3CBR%20%2F%3E%2B%7D%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%26nbsp%3Bint%20phy_aquantia_init(void)%3CBR%20%2F%3E%26nbsp%3B%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3Bphy_register(%26amp%3Baq1202_driver)%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3Bphy_register(%26amp%3Baq2104_driver)%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3Bphy_register(%26amp%3Baqr105_driver)%3B%3CBR%20%2F%3E%2B%26nbsp%3Bphy_register(%26amp%3Baqr108_driver)%3B%3CBR%20%2F%3E%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3Breturn%200%3B%3CBR%20%2F%3E%26nbsp%3B%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1101950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20The%20patch%20to%20support%20Aquantia%20AQR107%20in%20LS1043A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1101950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDoes%20any%20support%20for%20Aquantia%20AQR108%20in%20LS1043A%20%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎07-10-2016 09:47 PM
Updated by:
