LS2088ARDB - How to deploy TF-A binaries in QSPI NOR flash
Trusted Firmware for Cortex-A (TF-A) is an implementation of EL3 secure firmware. TF-A replaces PPA in secure firmware role.
           In LS2088ARDB, Boot option switching between parallel NOR boot and QSPI NOR boot cannot be performed using commands. Boot option switching can be done by adjusting DIP switch settings and jumper settings on the Reference Design Board. For details, see Layerscape Software Development Kit User Guide.
To migrate to the TF-A boot flow from the previous boot flow (with PPA), you need to compile the TF-A binaries, bl2_<boot_mode>.pbl and fip.bin, and flash these binaries on the specific boot medium on the board.
For QSPI NOR flash boot, you need to compile the following TF-A binaries.
TF-A binary nameComponents
bl2_qspi.pbl
  • BL2 binary: Platform initialization binary
  • RCW binary for QSPI NOR flash
fip.bin
  • BL31: Secure runtime firmware
  • BL32: Trusted OS, for example, OPTEE (optional)
  • BL33: U-Boot/UEFI image
Follow these steps to compile and deploy TF-A  binaries (bl2_qspi.pbl and fip.bin) in QSPI NOR flash.
  1. Compile RCW binary
  2. Compile U-Boot binary
  3. [Optional] Compile OPTEE binary
  4. Compile TF-A binaries (bl2_qspi.pbl and fip.bin) for QSPI NOR flash
  5. Program TF-A binaries to QSPI NOR flash
Step 1: Compile RCW binary
You need to compile the rcw_2000_qspi.bin binary to build the bl2_qspi.pbl binary.
Clone the  rcw repository and compile the PBL binary.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/rcw
  2. $ cd rcw
  3. $ git checkout -b <new branch name> <LSDK tag>. For example, $ git checkout -b LSDK-19.09 LSDK-19.09
  4. $ cd ls2088ardb
  5. If required, make changes to the rcw files.
  6. $ make
The compiled PBL binary for QSPI NOR flash on LS2088ARDB, rcw_2000_qspi.bin, is available at  rcw/ls2088ardb/FFFFFFFF_PP_HH_0x2a_0x41
See the rcw/ls2088ardb/README file for an explanation of the naming convention for the directories that contain the RCW source and binary files.
Step 2: Compile U-Boot binary
You need to compile the u-boot.bin binary to build the fip.bin binary.
Clone the u-boot repository and compile the U-Boot binary for TF-A.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/u-boot.git
  2. $ cd u-boot
  3. $ git checkout -b <new branch name> LSDK-<LSDK version>. For example, $ git checkout -b LSDK-19.09 LSDK-19.09
  4. $ export ARCH=arm64
  5. $ export CROSS_COMPILE=aarch64-linux-gnu-
  6. $ make distclean
  7. $ make ls2088ardb_tfa_defconfig
  8. $ make
If the make command shows the error "*** Your GCC is older than 6.0 and is not supported", ensure that you are using Ubuntu 18.04 64-bit version for building LSDK 18.12 and onwards U-Boot binary.
The compiled U-Boot image, u-boot.bin, is available at u-boot/.
Step 3: [Optional] Compile OP-TEE binary
You need to compile the tee.bin binary to build fip.bin with OPTEE. However, OPTEE is optional, you can skip the procedure to compile OPTEE if you want to build the FIP binary without OPTEE.
Clone the optee_os repository and build the OPTEE binary.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/optee_os
  2. $ cd optee_os
  6. $ make CFG_ARM64_core=y PLATFORM=ls-ls2088ardb
  7. $ aarch64-linux-gnu-objcopy -v -O binary out/arm-plat-ls/core/tee.elf out/arm-plat-ls/core/tee.bin
The compiled OPTEE image, tee.bin, is available at optee_os/out/arm-plat-ls/core/.
Step 4: Compile TF-A binaries for QSPI NOR flash
Clone the atf repository and compile the TF-A binaries, bl2_qspi.pbl and fip.bin.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/atf
  2. $ cd atf
  6. Build BL2 binary with OPTEE.
    • $ make PLAT=ls2088ardb bl2 SPD=opteed BOOT_MODE=qspi BL32=<path_to_optee_binary>/tee.bin pbl RCW=<path_to_rcw_binary>/rcw_2000_qspi.bin
      The compiled BL2 binaries, bl2.bin and bl2_qspi.pbl are available at atf/build/ls2088ardb/release/.
      For any update in the BL2 source code or RCW binary, the bl2_qspi.pbl binary needs to be recompiled.
      To compile the BL2 binary without OPTEE:
      make PLAT=ls2088ardb bl2 BOOT_MODE=qspi pbl RCW=<path_to_rcw_binary>/rcw_2000_qspi.bin
  7. Build FIP binary with OPTEE and without trusted board boot.
    • $ make PLAT=ls2088ardb fip BL33=<path_to_u-boot_binary>/u-boot.bin SPD=opteed BL32=<path_to_optee_binary>/tee.bin
      The compiled BL31 and FIP binaries, bl31.bin, fip.bin, are available at atf/build/ls2088ardb/release/.
      For any update in the BL31, BL32, or BL33 binaries, the fip.bin binary needs to be recompiled.
      To compile the FIP binary without OPTEE and without trusted board boot:
      make PLAT=ls2088ardb fip BOOT_MODE=sd BL33=<path_to_u-boot_binary>/u-boot.bin
      To compile the FIP binary with trusted board boot, refer the read me at <atf repository>/plat/nxp/README.TRUSTED_BOOT
Step 5: Program TF-A binaries to QSPI NOR flash
  1. Boot LS2088ARDB from QSPI. Ensure that the switches and jumpers are set to boot the board from QSPI. For booting from QSPI:
    SW5[1:8] = 1111 1111
    SW3[1:8] = 0011 0001
    SW4[1:8] = 0011 1111
    SW6[1:8] = 1111 1111
    SW7[1:8] = 0100 1010
    SW9[1:8] = 0100 0100
    SW8[1:8] = 0111 1111
  2. In addition to the above switch settings, make sure the following jumper settings are correct (for RDB Rev E and later).
    • J8 = 1-2 for QSPI boot, via onboard QSPI flash
    • J8 = 2-3 for QSPI boot, via QSPI emulator
    • J14 = 2-3, for QSPI boot
  3. For LS2088ARDB, in boot log, you'll see:
    Board: LS2088AE Rev1.1-RDB, Board Arch: V0, Board version: A, boot from vBank: 0
TF-A binaries can be loaded to LS2088ARDB from a TFTP server or from a mass storage device (SD, USB, or SATA).
Option 1: Load TF-A binaries from the TFTP server
Set up Ethernet connection
When board boots up, U-Boot prints a list of enabled Ethernet interfaces.
DPMAC1@xgmii, DPMAC2@xgmii, DPMAC3@xgmii, DPMAC4@xgmii, DPMAC5@xgmii, DPMAC6@xgmii, DPMAC7@xgmii, DPMAC8@xgmii
  1. Set server IP address to the IP address of the host machine on which you have configured the TFTP server.
    => setenv serverip <ipaddress1>
  2. Set ethact and ethprime as the ethernet interface connected to the TFTP server.
    See LS2088ARDB Ethernet port mapping for the mapping of Ethernet port names appearing on the chassis front panel with the port names in U-Boot and Linux.
    => setenv ethprime <name of interface connected to TFTP server>
    For example:
    => setenv ethprime DPMAC3@xgmii
    => setenv ethact <name of interface connected to TFTP server>
    For example:
    => setenv ethact DPMAC3@xgmii
  3. Set IP address of the board. You can set a static IP address or, if the board can connect to a dhcp server, you can use the dhcp command.
    Static IP address assignment:
    => setenv ipaddr <ipaddress2>
    => setenv netmask <subnet mask>
    => setenv gatewayip <gateway addr>
    Dynamic IP address assignment:
    => dhcp
  4. Save the settings. => saveenv
  5. Check the connection between the board and the TFTP server.
=> ping $serverip
Using DPMAC3@xgmii device
host 192.168.1.1 is alive
For details about the flash image layout for TF-A binaries, refer LSDK memory layout for TF-A boot flow.
  1. Program QSPI NOR flash: => sf probe 0:0
  2. Flash bl2_qspi.pbl:
    • => tftp 0xa0000000 bl2_qspi.pbl
    • => sf erase 0x0 +$filesize && sf write 0xa0000000 0x0 $filesize
  3. Flash fip.bin:
    • => tftp 0xa0000000 fip.bin
    • => sf erase 0x100000 +$filesize && sf write 0xa0000000 0x100000 $filesize
  4. Boot from QSPI NOR flash: => reset
    LS2088ARDB will boot with TF-A. In the boot log, you will see:
    => NOTICE: UDIMM 18ASF1G72AZ-2G3B1
    NOTICE: 16 GB DDR4, 64-bit, CL=15, ECC on, 256B, CS0+CS1
    NOTICE: 4 GB DDR4, 32-bit, CL=11, ECC on, CS0+CS1
    NOTICE: BL2: v1.5(release):LSDK-19.09
    NOTICE: BL2: Built : 15:19:13, Nov 11 2019
    NOTICE: BL31: v1.5(release):LSDK-19.09
    NOTICE: BL31: Built : 15:21:14, Nov 11 2019
    NOTICE: Welcome to LS2088 BL31 Phase
    U-Boot 2019.04 (Nov 11 2019 - 15:12:53 +0530)
    SoC: LS2088AE Rev1.1 (0x87090011)
    Clock Configuration:
    CPU0(A72):2000 MHz CPU1(A72):2000 MHz CPU2(A72):2000 MHz
    CPU3(A72):2000 MHz CPU4(A72):2000 MHz CPU5(A72):2000 MHz
    CPU6(A72):2000 MHz CPU7(A72):2000 MHz
    Bus: 800 MHz DDR: 2133.333 MT/s DP-DDR: 1600 MT/s
    Reset Configuration Word (RCW):
    00000000: 503040c0 50500050 00000000 00000000
    00000010: 00000000 00000000 00a00000 00000000
    00000020: 01e01180 00002581 00000000 00000000
    00000030: 00400c0b 00000000 00000000 00000000
    00000040: 00000000 00000000 00000000 00000000
    00000050: 00000000 00000000 00000000 00000000
    00000060: 00000000 00000000 00027000 00000000
    00000070: 412a0000 00040000
    Model: Freescale Layerscape 2080a RDB Board
Option 2: Load image from partition on mass storage device (SD, USB, or SATA)
  1. Select mass storage device to use.
    => mmc rescan
    => mmc info
    Or
    => usb start
    => usb info
    Or
    => scsi scan
    => scsi info
  2. Optional – List files on storage device
    => ls mmc <device:partition>
    For example:
    => ls mmc 0:2
    Or
    => ls usb <device:partition>
    For example:
    => ls usb 0:1
    Or
    => ls scsi <device:partition>
    For example:
    => ls scsi 0:2
    If the ls command fails to run, check that U-Boot in QSPI NOR flash supports the command by typing ls at the U-Boot prompt:
    => ls ls - Lists files in a directory (default)
    Usage: ls <interface> [<dev[:part]> [directory]] - Lists files in directory [directory] of partition [part] on device type [interface] and instance [dev].
    If U-Boot does not support this command, then update the composite firmware image in QSPI NOR flash.
    For steps to update composite firmware image in QSPI NOR flash, see Layerscape Software Development Kit User Guide .
    Use the following command if the SD card is formatted/created using LSDK flex-installer command:
    => load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] For example:
    => load mmc 0:2 $load_addr bl2_qspi.pbl Use the following command if the SD card is formatted/created on a Windows PC:
    => fatload <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] For example:
    => fatload mmc 0:2 $load_addr bl2_qspi.pbl Use the following command if the SD card is formatted/created on a Linux PC:
    => ext2load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] For example:
    => ext2load mmc 0:2 $load_addr bl2_qspi.pbl Also note that LSDK flex-installer command puts the images on the IInd partition, so 0:2 is used in the load command. If the SD card is formatted on Windows PC or Linux PC for single partition only, then 0 should be used instead of 0:2 in the fatload/ext2load command.
  3. Load bl2_qspi.pbl image from the storage device
    => load mmc 0:2 0xa0000000 <image name>
    => print filesize
    For example:
    => load mmc 0:2 0xa0000000 bl2_qspi.pbl
    => print filesize
    filesize=14379
    Or
    => load usb 0:2 0xa0000000 <image name>
    => print filesize
    Or
    => load scsi 0:2 0xa0000000 <image name>
    => print filesize
  4. Program bl2_qspi.pbl to QSPI NOR flash: => sf erase 0x0 +$filesize && sf write 0xa0000000 0x0 $filesize
  5. Load fip.bin image from the storage device
    => print filesize
    For example:
    => load mmc 0:2 0xa0000000 fip.bin
    => print filesize
    filesize=131510
    Or
    => print filesize
    Or
    => print filesize
  6. Program fip.bin to QSPI NOR flash: => sf erase 0x100000 +$filesize && sf write 0xa0000000 0x100000 $filesize
  7. Boot from QSPI NOR flash: => reset
%3CLINGO-SUB%20id%3D%22lingo-sub-1107212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS2088ARDB%20-%20TF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECortex-A%20%E7%94%A8%E3%81%AE%E4%BF%A1%E9%A0%BC%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20(TF-A)%20%E3%81%AF%E3%80%81EL3%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%99%E3%80%82TF-A%20%E3%81%AF%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%BD%B9%E5%89%B2%E3%81%A7%20PPA%20%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%20%20%20%20%20%20%20%20%20%20%20LS2088ARDB%E3%81%A7%E3%81%AF%E3%80%81%E3%83%91%E3%83%A9%E3%83%AC%E3%83%ABNOR%E3%83%96%E3%83%BC%E3%83%88%E3%81%A8QSPI%20NOR%E3%83%96%E3%83%BC%E3%83%88%E9%96%93%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%AF%E3%80%81%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7DIP%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fembedded-software%2Flinux-software-and-development-tools%2Flayerscape-software-development-kit-v19.09%3ALAYERSCAPE-SDK%3Ftab%3DDocumentation_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2014px%3B%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%3ELayerscape%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FA%3E%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E3%80%82%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3CP%3ETF-A%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%E4%BB%A5%E5%89%8D%E3%81%AE%3CSPAN%3E%3C%2FSPAN%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%83%AD%E3%83%BC%20(PPA%E3%82%92%E4%BD%BF%E7%94%A8)%20%E3%81%8B%E3%82%89%E3%80%81TF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_%3CBOOT_MODE%3E%3C%2FBOOT_MODE%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E.pbl%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E3%81%8A%E3%82%88%E3%81%B3%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3EQSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%96%E3%83%BC%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%20TF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%20width%3A%2052.809%25%3B%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2024px%3B%22%3E%3CTH%20style%3D%22width%3A%2018%25%3B%20height%3A%2024px%3B%22%3ETF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%90%8D%3C%2FTH%3E%3CTH%20style%3D%22width%3A%2031.8547%25%3B%20height%3A%2024px%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%3CTD%20style%3D%22height%3A%2024px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_qspi.pbl%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22height%3A%2024px%3B%22%3E%3CUL%3E%3CLI%3EBL2%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E5%88%9D%E6%9C%9F%E5%8C%96%E7%94%A8%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%3C%2FLI%3E%3CLI%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%94%A8%E3%81%AERCW%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%3C%2FLI%3E%3C%2FUL%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22height%3A%2076px%3B%22%3E%3CTD%20style%3D%22height%3A%2076px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22height%3A%2076px%3B%22%3E%3CUL%3E%3CLI%3EBL31%EF%BC%9A%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FLI%3E%3CLI%3EBL32%3A%20%E4%BF%A1%E9%A0%BC%E3%81%A7%E3%81%8D%E3%82%8BOS%E3%80%81%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81OPTEE%EF%BC%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89%3C%2FLI%3E%3CLI%3EBL33%3A%20U-Boot%2FUEFI%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FLI%3E%3C%2FUL%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81TF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20(%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_qspi.%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Epbl%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eand%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin)%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%82%92%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3COL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3ERCW%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3EU-Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%5B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5D%20OP%E2%80%91TEE%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3ETF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_qspi.%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EPBL%3C%2FSPAN%3E%E3%81%8A%E3%82%88%E3%81%B3%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin)%20%3C%2FSPAN%3E%3C%2FSPAN%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%94%A8%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3ETF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%3C%2FLI%3E%3C%2FOL%3E%3CH1%20id%3D%22toc-hId-380695467%22%20id%3D%22toc-hId-380695467%22%20id%3D%22toc-hId-1304191667%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%201%3A%20RCW%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FH1%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw_2000_qspi.bin%3C%2FSPAN%3E%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20bl2_qspi.pbl%3C%2FSPAN%3E%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%3C%2FSPAN%3E%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%80%81PBL%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20data-ccp-props%3D%22%7B%22%20201341983%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%E2%80%AFgit%20clone%E2%80%AF%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Frcw%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%E2%80%AF%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3Ecd%20rcw%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20git%20checkout%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CLSDK%20tag%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%80%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20git%20checkout%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20-b%20LSDK-19.09%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20LSDK-19.09%20%E3%80%8D%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%26nbsp%3Bcd%20ls2088ardb%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81rcw%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%20make%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%3ELS2088ARDB%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw_2000_qspi.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%AE%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20PBL%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AF%E3%80%81%3CSPAN%20data-ccp-props%3D%22%7B%22%20201341983%3D%22%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%2Fls2088ardb%2FFFFFFFFF_PP_HH_0x2a_0x41%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%20%E3%81%8B%E3%82%89%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CPRE%20___default_attr%3D%22info%22%20_alert%3D%22info%22%20_modifiedtitle%3D%22true%22%20jivemacro%3D%22alert%22%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3ERCW%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E5%91%BD%E5%90%8D%E8%A6%8F%E5%89%87%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%2Fls2088ardb%2FREADME%3C%2FSPAN%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CH1%20id%3D%22toc-hId--1426758996%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId--1426758996%22%20id%3D%22toc-hId--503262796%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%972%EF%BC%9AU-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FH1%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot.bin%3C%2FSPAN%3E%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%26nbsp%3B%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6fip.bin%3C%2FSPAN%3E%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%26nbsp%3B%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Eu-boot%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FSPAN%3Erepository%20%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%80%81TF-A%20%E3%81%AE%20U-Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%E2%80%AFgit%20clone%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CA%20data-content-finding%3D%22Community%22%20style%3D%22color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20text-decoration%3A%20inherit%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Fu-boot.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3Ecd%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3Eu-boot%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20LSDK-.%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20LSDK-19.09%20%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eexport%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20ARCH%3Darm64%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%83%89%E3%83%AB%3C%2FSPAN%3E%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20CROSS_COMPILE%3D%20aarch64-linux-gnu-%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20make%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Edistclean%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%20ls2088ardb_tfa_defconfig%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20make%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CPRE%20___default_attr%3D%22info%22%20_alert%3D%22info%22%20_modifiedtitle%3D%22true%22%20jivemacro%3D%22alert%22%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%3C%2FSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20***%20GCC%20%E3%81%AF%206.0%20%E3%82%88%E3%82%8A%E5%8F%A4%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%3C%2FSPAN%3E%20%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81LSDK%2018.12%20%E4%BB%A5%E9%99%8D%E3%81%AE%20U-Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%20Ubuntu%2018.04%2064%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FPRE%3E%3C%2FPRE%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20U-Boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%AF%20%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%8B%E3%82%89%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1060753837%22%20style%3D%22border%3A%200px%3B%22%20id%3D%22toc-hId-1060753837%22%20id%3D%22toc-hId-1984250037%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%203%3A%20%5B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EOP-TEE%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Etee.bin%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E3%82%92%20OPTEE%20%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81OPTEE%20%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81OPTEE%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%20FIP%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EOPTEE%20%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%92%E7%9C%81%E7%95%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eoptee_os%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%80%81OPTEE%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20git%20clone%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Foptee_os%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecd%20optee_os%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20LSDK-%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20LSDK-19.09%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%26nbsp%3Bexport%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3BARCH%3Darm%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20export%20CROSS_COMPILE%3Daarch64-linux-gnu-%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20make%20CFG_ARM64_core%3Dy%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3Dls-ls2088ardb%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20aarch64-linux-gnu-objcopy%20-v%20-O%20binary%20out%2Farm-plat-ls%2Fcore%2Ftee.elf%20out%2Farm-plat-ls%2Fcore%2Ftee.bin%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FOPTEE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Etee.bin%3C%2FSPAN%3E%E3%81%AF%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eoptee_os%2Fout%2Farm-plat-ls%2Fcore%2F%3C%2FSPAN%3E%E3%81%A7%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH1%20id%3D%22toc-hId--746700626%22%20id%3D%22toc-hId--746700626%22%20id%3D%22toc-hId-176795574%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%204%3A%20TF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FH1%3E%3CP%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eatf%3C%2FSPAN%3E%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%80%81TF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20bl2_qspi%20%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EPBL%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%8A%E3%82%88%E3%81%B3%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Egit%20clone%20%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Fatf%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecd%20atf%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20LSDK-.%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20LSDK-19.09%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eexport%20ARCH%3Darm64%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20export%20CROSS_COMPILE%3Daarch64-linux-gnu-%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EOP%E2%80%91TEE%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20BL2%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%24%20make%20PLAT%3Dls2088ardb%20bl2%20SPD%3Dopteed%20BOOT_MODE%3Dqspi%20BL32%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CPATH_TO_OPTEE_BINARY%3E%2F%3C%2FPATH_TO_OPTEE_BINARY%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Etee.bin%20pbl%20RCW%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CPATH_TO_RCW_BINARY%3E%3C%2FPATH_TO_RCW_BINARY%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%2Frcw_2000_qspi.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20BL2%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%80%81%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2.bin%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%81%8A%E3%82%88%E3%81%B3%20bl2_qspi.pbl%3C%2FSPAN%3E%20%E3%81%AF%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eatf%2Fbuild%2Fls2088ardb%2Frelease%2F%3C%2FSPAN%3E%20%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3EBL2%20%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%20RCW%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_qspi.pbl%3C%2FSPAN%3E%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E5%86%8D%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3EOPTEE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%ABBL2%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%20PLAT%3Dls2088ardb%20bl2%20BOOT_MODE%3Dqspi%20pbl%20RCW%3D%3CPATH_TO_RCW_BINARY%3E%2F%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ercw_2000_qspi.bin%3C%2FSPAN%3E%3C%2FPATH_TO_RCW_BINARY%3E%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EOP%E2%80%91TEE%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81Trusted%20Board%20Boot%20%E3%81%AA%E3%81%97%E3%81%A7%20FIP%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%26nbsp%3Bmake%20PLAT%3Dls2088ardb%20fip%20BL33%3D%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CPATH_TO_U-BOOT_BINARY%3E%2F%3C%2FPATH_TO_U-BOOT_BINARY%3E%3C%2FSPAN%3Eu-boot.bin%20SPD%3Dopteed%20BL32%3D%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CPATH_TO_OPTEE_BINARY%3E%2F%3C%2FPATH_TO_OPTEE_BINARY%3E%3C%2FSPAN%3Etee.bin%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20BL31%20%E3%81%A8%20FIP%20%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl31.bin%3C%2FSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3Efip%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%AF%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eatf%2Fbuild%2Fls2088ardb%2Frelease%2F%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%8B%E3%82%89%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3EBL31%E3%80%81BL32%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFBL33%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%9B%B4%E6%96%B0%E3%82%92%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E5%86%8D%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3EOP%E2%80%91TEE%20%E3%81%8A%E3%82%88%E3%81%B3%20Trusted%20Board%20Boot%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%20FIP%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%20PLAT%3Dls2088ardb%20fip%20BOOT_MODE%3Dsd%20BL33%3D%3CPATH_TO_U-BOOT_BINARY%3E%2Fu-boot.bin%3C%2FPATH_TO_U-BOOT_BINARY%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%A9%E3%82%B9%E3%83%86%E3%83%83%E3%83%89%20%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%96%E3%83%BC%E3%83%88%E3%81%A7%20FIP%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81read%20me%20at%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CATF%20repository%3D%22%22%3E%2Fplat%2Fnxp%2FREADME%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82TRUSTED_BOOT%3C%2FATF%3E%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FPRE%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FOL%3E%3CH1%20id%3D%22toc-hId-1740812207%22%20id%3D%22toc-hId-1740812207%22%20id%3D%22toc-hId--1630658889%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%975%3ATF-A%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%3C%2FH1%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3EQSPI%E3%81%AEBoot%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3ELS2088ARDB%3C%2FSPAN%3E%E3%80%82%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A8%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%81%8C%20QSPI%20%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E5%85%83%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014.6667px%3B%22%3EQSPI%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW5%5B1%3A8%5D%20%3D%201111%201111%3CBR%20%2F%3ESW3%5B1%3A8%5D%20%3D%200011%200001%3CBR%20%2F%3ESW4%5B1%3A8%5D%20%3D%200011%201111%3CBR%20%2F%3ESW6%5B1%3A8%5D%20%3D%201111%201111%3CBR%20%2F%3ESW7%5B1%3A8%5D%20%3D%200100%201010%3CBR%20%2F%3ESW9%5B1%3A8%5D%20%3D%200100%200100%3CBR%20%2F%3ESW8%5B1%3A8%5D%20%3D%200111%201111%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84(RDB%20Rev%20E%E4%BB%A5%E9%99%8D%E3%81%AE%E5%A0%B4%E5%90%88)%E3%80%82%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3EJ8%20%3D%201-2%20(QSPI%20%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8)%E3%80%81%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%20QSPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%B5%8C%E7%94%B1%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3EJ8%20%3D%202-3%20(QSPI%20%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%E3%80%81QSPI%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E7%B5%8C%E7%94%B1)%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3EJ14%20%3D%202-3%E3%80%81QSPI%20%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3ELS2088ARDB%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3ALS2088AE%20Rev1.1-RDB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%A2%E3%83%BC%E3%83%81%3AV0%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3AA%E3%80%81vBank%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%3A0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId-634422322%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId-634422322%22%20id%3D%22toc-hId-1557918522%22%3E%3C%2FH3%3E%3CP%3E%3CSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ETF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AF%E3%80%81TFTP%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E8%A3%85%E7%BD%AE%20(SD%E3%80%81USB%E3%80%81SATA)%20%E3%81%8B%E3%82%89%20LS2088ARDB%20%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1173032141%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId--1173032141%22%20id%3D%22toc-hId--249535941%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%201%3A%20TFTP%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%20TF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3C%2FH3%3E%3CH3%20id%3D%22toc-hId-1314480692%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId-1314480692%22%20id%3D%22toc-hId--2056990404%22%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%3C%2FH3%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81U-Boot%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EDPMAC1%40xgmii%2C%20DPMAC2%40xgmii%2C%20DPMAC3%40xgmii%2C%20DPMAC4%40xgmii%2C%20DPMAC5%40xgmii%2C%20DPMAC6%40xgmii%2C%20DPMAC7%40xgmii%2C%20DPMAC8%40xgmii%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E3%80%81TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20serverip%20%3CIPADDRESS1%3E%3C%2FIPADDRESS1%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%3Eethact%3C%2FSPAN%3E%20%E3%81%A8%20%3CSPAN%3Eethprime%3C%2FSPAN%3E%20%E3%82%92%20TFTP%20%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EU-Boot%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211685%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22341964%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344335%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3E%20LS2088ARDB%E3%81%8A%E3%82%88%E3%81%B3%3C%2FA%3E%3CSPAN%3E%3C%2FSPAN%3E%20Linux%20%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E5%90%8D%E3%81%A8%20%E3%82%B7%E3%83%A3%E3%83%BC%E3%82%B7%E3%81%AE%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E5%90%8D%E3%81%AE%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethprime%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethprime%20DPMAC3%40xgmii%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethact%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%20connected%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethact%20DPMAC3%40xgmii%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%9D%99%E7%9A%84%20IP%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%20dhcp%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%20dhcp%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CP%3E%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20ipaddr%20%3CIPADDRESS2%3E%3C%2FIPADDRESS2%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20netmask%20%3CSUBNET%20mask%3D%22%22%3E%3C%2FSUBNET%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20gatewayip%20%3CGATEWAY%20addr%3D%22%22%3E%3C%2FGATEWAY%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8B%95%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20dhcp%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3D%26gt%3B%20saveenv%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E9%96%93%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ping%20%24serverip%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EDPMAC3%40xgmii%3C%2FSPAN%3E%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ehost%20192.168.1.1%20is%20alive%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--492973771%22%20id%3D%22toc-hId--492973771%22%20id%3D%22toc-hId-430522429%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3ETFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89TF-A%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FH3%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230f7198%3B%22%3ETF-A%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8C%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342651%22%20style%3D%22text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3ETF-A%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%20LSDK%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FA%3E%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230f7198%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FPRE%3E%3COL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%20%26gt%3B%20sf%E3%83%97%E3%83%AD%E3%83%BC%E3%83%960%3A0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EFlash%20%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_qspi.pbl%3C%2FSPAN%3E%3A%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3D%26gt%3B%26nbsp%3B%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3Etftp%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B0x%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3Ea%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E0000000%E2%80%AFbl2_qspi.pbl%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3C%2FSPAN%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20%E6%B6%88%E5%8E%BB%200x0%20%2B%24filesize%20%26amp%3B%20sf%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%200xa0000000%200x0%20%24filesize%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014.6667px%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3EFlash%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3A%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Etftp%200xa0000000%20fip.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014.6667px%3B%22%3E%3CSPAN%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESF%20%E6%B6%88%E5%8E%BB%200x100000%20%2B%24filesize%20%26amp%3B%20sf%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%200xa0000000%200x100000%20%24filesize%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSPAN%3E%3CSPAN%3E%20%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%3D%26gt%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3ELS2088ARDB%E3%81%AFTF-A%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20style%3D%22margin%3A%200%200%200%2040px%3B%20border%3A%20none%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3BNOTICE%3A%20UDIMM%2018ASF1G72AZ-2G3B1%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CBLOCKQUOTE%20style%3D%22margin%3A%200%200%200%2040px%3B%20border%3A%20none%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%3A%2016%20GB%20DDR4%E3%80%8164%20%E3%83%93%E3%83%83%E3%83%88%E3%80%81CL%3D15%E3%80%81ECC%20%E3%82%AA%E3%83%B3%E3%80%81256B%E3%80%81CS0%2BCS1%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%3A%20UDIMM%2018ASF1G72AZ-2G3B1%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%3A%204%20GB%20DDR4%E3%80%8132%20%E3%83%93%E3%83%83%E3%83%88%E3%80%81CL%3D11%E3%80%81ECC%20%E3%82%AA%E3%83%B3%E3%80%81CS0%2BCS1%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBL2%3Av1.5(%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%3ALSDK-19.09%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%3A%20BL2%3A%20%E6%A7%8B%E7%AF%89%20%3A%202019%E5%B9%B411%E6%9C%8811%E6%97%A5%2015%3A19%3A13%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBL31%3Av1.5(%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%3ALSDK-19.09%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%3ABL31%3A2019%E5%B9%B411%E6%9C%8811%E6%97%A515%3A21%3A14%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%3ALS2088%20BL31%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%B8%E3%82%88%E3%81%86%E3%81%93%E3%81%9D%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EU-Boot%202019.04%20(2019%E5%B9%B411%E6%9C%8811%E6%97%A5%20-%2015%3A12%3A53%20%2B0530)%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESoC%3ALS2088AE%20Rev1.1(0x87090011)%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20CPU0(A72)%3A2000MHz%20CPU1(A72)%3A2000MHz%20CPU2(A72)%3A2000%20MHz%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20CPU3(A72)%3A2000%20MHz%20CPU4(A72)%3A2000%20MHz%20CPU5(A72)%3A2000%20MHz%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20CPU6(A72)%3A2000%20MHz%20CPU7(A72)%3A2000%20MHz%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%E3%83%90%E3%82%B9%3A800%20MHz%20DDR%3A2133.333%20MT%2F%E7%A7%92%20DP-DDR%3A1600%20MT%2F%E7%A7%92%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%A7%8B%E6%88%90%E3%83%AF%E3%83%BC%E3%83%89(RCW)%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000000000%3A%20503040c0%2050500050%2000000000%2000000000%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000000010%3A%2000000000%200000000%2000a00000%2000000000%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000000020%3A%2001E01180%2000002581%20000000000%2000000000%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000000030%3A%2000400c0b%2000000000%20000000000%2000000000%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000000040%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000000050%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000000060%3A%2000000000%2000000000%2000027000%2000000000%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000000070%3A%20412A0000%2000040000%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%A2%E3%83%87%E3%83%AB%3A%20Freescale%20Layerscape%202080a%20RDB%20Board%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3ALS2088AE%20Rev1.1-RDB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%A2%E3%83%BC%E3%83%81%3AV0%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3AA%E3%80%81vBank%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%3A0%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3C%2FLI%3E%3C%2FOL%3E%3CH2%20id%3D%22toc-hId--503476875%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%22%20id%3D%22toc-hId--503476875%22%20id%3D%22toc-hId-420019325%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%202%EF%BC%9A%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%88SD%E3%80%81USB%E3%81%BE%E3%81%9F%E3%81%AF%20SATA%EF%BC%89%E4%B8%8A%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3C%2FH2%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20rescan%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20start%3C%2FSPAN%3E%0A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20scan%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20info%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BB%BB%E6%84%8F%20%E2%80%93%20%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%200%3A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%200%3A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%200%3A2%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3Els%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81U-Boot%20%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%A7%20ls%20%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%80%81QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%20U-Boot%20%E3%81%8C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%3C%2FSPAN%3E%0Als%20-%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%20(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E3%81%84%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20ls%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5B%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%5D%5D%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%20-%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%97%5Binterface%5D%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%5Bdev%5D%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%5Bpart%5D%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%5Bdirectory%5D%E3%81%AB%E3%81%82%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%AA%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%20%E3%81%A7%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%82%B8%E3%83%83%E3%83%88%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%82%B8%E3%83%83%E3%83%88%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fembedded-software%2Flinux-software-and-development-tools%2Flayerscape-software-development-kit-v19.09%3ALAYERSCAPE-SDK%3Ftab%3DDocumentation_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2014px%3B%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%3E%20Layerscape%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%AC%E3%82%A4%E3%83%89%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FPRE%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8CLSDK%20flex-installer%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%2F%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E8%B2%A0%E8%8D%B7%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5B%3CADDR%3E%20%5B%3CFILENAME%3E%20%5Bbytes%20%5Bpos%5D%5D%5D%5D%5D%3C%2FFILENAME%3E%3C%2FADDR%3E%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%20%E4%BE%8B%E3%81%88%E3%81%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%E8%B2%A0%E8%8D%B7%20mmc%200%3A2%20%24load_addr%20bl2_qspi.pbl%0ASD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8CWindows%20PC%E3%81%A7%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%2F%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20fatload%20%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5B%3CADDR%3E%20%5B%3CFILENAME%3E%20%5Bbytes%20%5Bpos%5D%5D%5D%5D%5D%3C%2FFILENAME%3E%3C%2FADDR%3E%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%0A%E4%BE%8B%E3%81%88%E3%81%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%E8%84%82%E8%82%AA%E8%B2%A0%E8%8D%B7%20mmc%200%3A2%20%24load_addr%20bl2_qspi.pbl%0ASD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8CLinuxPC%E3%81%A7%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%2F%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ext2load%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5B%3CADDR%3E%20%5B%3CFILENAME%3E%20%5Bbytes%20%5Bpos%5D%5D%5D%5D%5D%3C%2FFILENAME%3E%3C%2FADDR%3E%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%20%E4%BE%8B%E3%81%88%E3%81%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3Eext2load%20mmc%200%3A2%20%24load_addr%20bl2_qspi.pbl%0A%E3%81%BE%E3%81%9F%E3%80%81LSDK%20flex-installer%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%20IInd%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81load%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%81%AF%200%3A2%20%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%20Windows%20PC%20%E3%81%BE%E3%81%9F%E3%81%AF%20Linux%20PC%20%E3%81%A7%E5%8D%98%E4%B8%80%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%BF%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81fatload%2Fext2load%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%200%3A2%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%200%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FPRE%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3Ebl2_qspi.pbl%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AE%E7%94%BB%E5%83%8F%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%200xa0000000%26nbsp%3Bbl2_qspi.pbl%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3D14379%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20usb%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20scsi%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_qspi.pbl%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EQSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%B8%3A%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3Esf%20%E6%B6%88%E5%8E%BB%200x0%20%2B%24filesize%20%26amp%3B%20sf%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF0xa0000000%200x0%20%24filesize%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014.6667px%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%93%E3%83%B3%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AE%E7%94%BB%E5%83%8F%3C%2FSPAN%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%200xa0000000%26nbsp%3Bfip.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3D131510%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20usb%200%3A2%200xa0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20scsi%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%20%E3%81%8B%E3%82%89%20%3C%2FSPAN%3EQSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%E3%81%B8%3A%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20%E6%B6%88%E5%8E%BB%200x100000%20%2B%24filesize%20%26amp%3B%20sf%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%200xa0000000%200x100000%20%24filesize%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%20%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%3D%26gt%3B%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%20reset%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3ELS2088ARDB%E3%81%AFTF-A%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1107212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:02 AM
更新者:
