LS1046ARDB - How to update U-Boot binary in QSPI NOR flash
This how-to topic is applicable for only LSDK 18.09 and older releases.
Follow these steps to update the U-Boot binary in QSPI NOR flash.
Prerequisites
  • Ubuntu 18.04 64-bit should be installed on the Linux host machine for building LSDK 18.06 or LSDK 18.09 U-Boot binary.
cpld reset boots the board from QSPI NOR flash0 and cpld reset altbank boots the board from QSPI NOR flash1.
sf probe 0:1 means that the alternate bank will be written to. So, if the board boots from QSPI NOR flash0 and sf probe 0:1 is entered at the U-Boot prompt, the commands that follow will program QSPI NOR flash1.
Compiling U-Boot binary
Clone the u-boot repository.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/u-boot.git
  2. $ cd u-boot
  3. $ git checkout -b <new branch name> LSDK-<LSDK version>. For example, $ git checkout -b LSDK-18.09 LSDK-18.09
  4. $ export ARCH=arm64
  5. $ export CROSS_COMPILE=aarch64-linux-gnu-
  6. $ make distclean
  7. $ make ls1046ardb_qspi_defconfig
  8. If required, make changes to the U-Boot files.
  9. $ make
If the make command shows the error "*** Your GCC is older than 6.0 and is not supported", ensure that you are using Ubuntu 18.04 64-bit version for building LSDK 18.06 or LSDK 18.09 U-Boot binary.
The compiled U-Boot image, u-boot.bin, is available in the directory u-boot/.
Flashing U-Boot binary to QSPI NOR flash
U-Boot image can be loaded to LS1046ARDB from a TFTP server or from a mass storage device (SD, USB, or SATA).
Option 1: Load image from the TFTP server
  1. Boot LS1046ARDB from QSPI. Ensure that the switches are set to boot the board from QSPI. For booting from QSPI, SW5[1:8] = 00100010
  2. Boot from QSPI NOR flash0: => cpld reset
    In boot log, you’ll see:
    Board: LS1046ARDB, boot from QSPI vBank 0
Set up Ethernet connection
When the board boots up, U-Boot prints a list of enabled Ethernet interfaces.
FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6, FM1@TGEC1, FM1@TGEC2
  1. Set server IP to the IP of the host machine on which you have configured the TFTP server.
    => setenv serverip <ipaddress1>
  2. Set ethact and ethprime as the Ethernet interface connected to the TFTP server.
    See LS1046ARDB Ethernet port mapping for the mapping of Ethernet port names appearing on the chassis front panel with the port names in U-Boot and Linux.
    => setenv ethprime <name of interface connected to TFTP server>
    For example:
    => setenv ethprime FM1@DTSEC4
    => setenv ethact <name of interface connected to TFTP server>
    For example:
    => setenv ethact FM1@DTSEC4
  3. Set IP address of the board. You can set a static IP address or, if the board can connect to a dhcp server, you can use the dhcp command.
    Static IP address assignment:
    => setenv ipaddr <ipaddress2>
    => setenv netmask <subnet mask>
    Dynamic IP address assignment:
    => dhcp
  4. Save the settings.
    => saveenv
  5. Check the connection between the board and the TFTP server.
=> ping $serverip
Using FM1@DTSEC4 device
host 192.168.1.1 is alive
Load U-Boot image from the TFTP server
  1. Program QSPI NOR flash1: => sf probe 0:1
  2. Flash U-Boot image:
    1. => tftp 0xa0000000 u-boot.bin
    2. => print filesize
      filesize=ae84a
  3. Program U-Boot image to QSPI NOR flash: => sf erase 0x100000 +$filesize && sf write 0xa0000000 0x100000 $filesize
    Address 0x100000 is the location of U-Boot in QSPI NOR flash.  Refer Flash layout for boot flow with PPA – LSDK 18.09 and older releases for the complete flash memory layout.
  4. Boot from QSPI NOR flash1: => cpld reset altbank
    Board: LS1046ARDB, boot from QSPI vBank 4
    Ensure that SD card, USB flash drive, or SCSI hard disk installed with LSDK Ubuntu distribution is plugged into the board to boot the board to Ubuntu. If U-Boot does not find LSDK on a mass storage device, it will boot TinyDistro from lsdk_linux_arm64_ tiny.itb stored in QSPI NOR flash.
Option 2: Load image from partition on mass storage device (SD, USB, or SATA)
  1. Boot LS1046ARDB from QSPI NOR flash. Ensure that the switches are set to boot the board from QSPI. For booting from QSPI, SW5[1:8] = 00100010
  3. Select mass storage device to use.
    => mmc rescan
    => mmc info
    Or
    => usb start
    => usb info
    Or
    => scsi scan
    => scsi info
  4. Optional – List files on storage device
    => ls mmc <device:partition>
    For example:
    => ls mmc 0:3
    System Volume Information/
    714826 u-boot.bin
    1 file(s), 1 dir(s)
    Or
    => ls usb <device:partition>
    For example:
    => ls usb 0:1
    Or
    => ls scsi <device:partition>
    For example:
    => ls scsi 0:2
    If the ls command fails to run, check that U-Boot in QSPI NOR flash0 supports the command by typing ls at the U-Boot prompt:
    => ls ls - Lists files in a directory (default)
    Usage: ls <interface> [<dev[:part]> [directory]]
    - Lists files in directory [directory] of partition [part] on device type [interface] and instance [dev].
    If U-Boot does not support this command, then update the composite firmware image in QSPI NOR flash0.
    For steps to update composite firmware image in QSPI NOR flash, see LS1046ARDB - How to update composite firmware image in QSPI NOR flash.
  5. Program QSPI NOR flash1: => sf probe 0:1
  6. Load U-Boot image from the storage device.
    => load mmc <device:partition> a0000000 <image name>
    => print filesize
    For example:
    => load mmc 0:3 a0000000 u-boot.bin
    714826 bytes read in 52 ms (13.1 MiB/s)
    => print filesize
    filesize=ae84a
    Or
    => load usb <device:partition> a0000000 <image name>
    => print filesize
    Or
    => load scsi <device:partition> a0000000 <image name>
    => print filesize
  7. Program U-Boot image to QSPI NOR flash: => sf erase 0x100000 +$filesize && sf write 0xa0000000 0x100000 $filesize
  8. Boot from QSPI NOR flash1: => cpld reset altbank
コメント
I faced a serious problem about QSPI booting problem after update.
According to the guide, I did make QSPI flash#1 updated.
And I tried to update QSPI flash#0 to keep the same version as the flash #1. I erased & wrote it.
After that, my board can't boot from flash#0. It can only boot from flash#1 and SD card.
I copied the contents of flash#1 to memory and I wrote to flash#0.
I checked the content of flash#0 is the same as flash#1.
When I boot from flash#1 and then command "cpld reset" then it can boot from flash#0. That means the content of flash#0 is right to boot I guess.
Would you help me with that?
From the problem description, it seems that after booting from QSPI NOR flash1, if you enter the command “cpld reset” the board successfully boots from QSPI NOR flash0.  However, if you power on the board or reset the board, the board will not boot from QSPI NOR flash0.
One item to check is that the switch settings are correct when trying to boot from QSPI NOR flash0.  The QorIQ LS1046A Reference Design Board Getting Started Guide has a table that lists the switch settings to use for the different boot sources (QSPI NOR flash0, QSPI NOR flash1, and SD card).  This table can be found in section 12 titled “LS1046ARDB boot sources.” This section also has a table that lists the CPLD commands that can be used to override the switch settings.
Hope this resolves the issue.
Thanks.
JS Park,
I have the same problem, I erased and wrote QSPI vBank0 and now LS1046A-RDB won't boot from vBank0.
vBank4 and SD start with no problem using the switch positions detailed in the QorIQ LS1046A Reference Design Board Getting Started Guide.
vBank0 and vBank4 are identical copies, did you find a solution to boot vBank0?
Penman
I don't have found any solutions by using switches, commands & codes.
I made the NOR flash normal after erasing it by Code Worrier.
And then, the flash is working properly. I just guess that the first sector of NOR flash was locked and Code Worrier was able to resolve the situation.
I hope it would be helpful to you.
Hi, I flashed QSPI NOR flash 1 with a newly built U-Boot binary by following the documented steps and then I flahed QSPI NOR flash 0 with the same U-Boot binary. However, I am able to boot the board from both flash 0 and flash 1. The issue is not reproducing for me.
Thanks.
Hi Swati, thank you for looking into this however my experience was similar to JS Park; despite following the steps above directed to NOR flash 0, I also noticed that the first 0x8000 bytes would silently fail to erase/write. It may not be a coincidence that this is also the first 8 4kB 'hybrid' sectors of S25F512S though I don't have drivers to lock/unlock the QSPI configuration register default settings. I was lucky to have access to a CodeWarrior and TAP/cable and recover this.
%3CLINGO-SUB%20id%3D%22lingo-sub-1127772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AEU-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E3%81%93%E3%81%AE%E3%83%8F%E3%82%A6%E3%83%84%E3%83%BC%20%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81LSDK%2018.09%20%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AE%E3%81%BF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AEU-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CH1%20id%3D%22toc-hId-382547500%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId-382547500%22%20id%3D%22toc-hId-1303146038%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2024px%3B%22%3E%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%3C%2FSPAN%3E%3C%2FH1%3E%3CUL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3ELSDK%2018.06%20%E3%81%BE%E3%81%9F%E3%81%AF%20LSDK%2018.09%20U-Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81Linux%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%20Ubuntu%2018.04%EF%BC%8864%20%E3%83%93%E3%83%83%E3%83%88%EF%BC%89%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecpld%20reset%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%E3%81%AFQSPI%20NOR%20flash0%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecpld%20reset%20altbank%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AFQSPI%20NOR%20flash1%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CDIV%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20probe%200%3A1%3C%2FSPAN%3E%E3%81%AF%E4%BB%A3%E6%9B%BF%E3%83%90%E3%83%B3%E3%82%AF%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8CQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A50%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81U-Boot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%A7%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20probe%200%3A1%3C%2FSPAN%3E%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AB%E7%B6%9A%E3%81%8F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AFQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1424906963%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2026px%3B%22%20id%3D%22toc-hId--1424906963%22%20id%3D%22toc-hId--504308425%22%3EU%E2%80%91Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Eu-boot%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%3CSPAN%3E%24%E2%80%AFgit%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Fu-boot.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%24%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Ecd%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Eu-boot%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%24%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Egit%20checkout%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E-b%20%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%26nbsp%3B%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3ELSDK-%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%E2%80%AF%24%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3Egit%20checkout%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E-b%20LSDK-18.09%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ELSDK-18.09%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%20export%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%26nbsp%3BARCH%3Darm64%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%20export%20CROSS_COMPILE%3D%3CSPAN%20lang%3D%22EN-US%22%3Eaarch64-linux-gnu-%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%20make%26nbsp%3B%3CSPAN%20lang%3D%22EN-US%22%3Edistclean%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%20make%20ls10%3CSPAN%20lang%3D%22EN-US%22%3E46ardb_qspi%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E_defconfig%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EU-Boot%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%20make%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230f7198%3B%20border%3A%200px%3B%22%3E%E3%82%82%E3%81%97%20make%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230f7198%3B%20border%3A%200px%3B%22%3E%20***%20GCC%E3%81%8C6.0%E3%82%88%E3%82%8A%E5%8F%A4%E3%81%8F%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230f7198%3B%20border%3A%200px%3B%22%3E%E3%80%8D%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81LSDK%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230f7198%3B%22%3E%2018.06%E3%81%BE%E3%81%9F%E3%81%AFLSDK%2018.09%3C%2FSPAN%3E%20U-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81Ubuntu%3CSPAN%20style%3D%22color%3A%20%230f7198%3B%20border%3A%200px%3B%22%3E%2018.04%2064%E3%83%93%E3%83%83%E3%83%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20U-Boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Eu-%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Eboot%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%81%AF%E3%80%81%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2F%3C%2FSPAN%3E%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1062605870%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2026px%3B%22%20id%3D%22toc-hId-1062605870%22%20id%3D%22toc-hId-1983204408%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3EU-Boot%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%82%92%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2019.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3EU-Boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%88SD%E3%80%81USB%E3%80%81SATA%EF%BC%89%E3%81%8B%E3%82%89LS1046ARDB%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1753167344%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId-1753167344%22%20id%3D%22toc-hId--1621201414%22%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--54287119%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--54287119%22%20id%3D%22toc-hId-866311419%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%201%EF%BC%9ATFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%81%8B%E3%82%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3C%2FH2%3E%3COL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3ELS1046ARDB%E3%82%92QSPI%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8CQSPI%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82QSPI%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%81%8B%E3%82%89%3C%2FSPAN%3E%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW5%5B1%3A8%5D%20%3D%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00100010%3C%2FSPAN%3E%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3EQSPI%20NOR%20flash0%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20cpld%20reset%3C%2FSPAN%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBoard%3A%20LS1046ARDB%2C%20boot%20from%20QSPI%20vBank%200%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId-636274355%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId-636274355%22%20id%3D%22toc-hId-1556872893%22%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%3C%2FH3%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81U-Boot%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EFM1%40DTSEC3%20%5BPRIME%5D%E3%80%81FM1%40DTSEC4%E3%80%81FM1%40DTSEC5%E3%80%81FM1%40DTSEC6%E3%80%81FM1%40TGEC1%E3%80%81FM1%40TGEC2%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AEIP%E3%82%92%E3%80%81TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AEIP%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20serverip%20%3CIPADDRESS1%3E%3C%2FIPADDRESS1%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethact%3C%2FSPAN%3E%E3%81%A8%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethprime%3C%2FSPAN%3E%E3%82%92TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E3%82%B7%E3%83%A3%E3%83%BC%E3%82%B7%E3%81%AE%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E5%90%8D%E3%81%A8%E3%80%81U-Boot%E3%81%8A%E3%82%88%E3%81%B3Linux%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E5%90%8D%E3%81%AE%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211685%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22342200%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342200%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3ELS1046ARDB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%3C%2FA%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FDIV%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3Esetenv%20ethprime%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethprime%20FM1%40DTSEC4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20ethact%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%20connected%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethact%20FM1%40DTSEC4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8Cdhcp%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Edhcp%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3C%2FSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%EF%BC%9A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20ipaddr%20%3CIPADDRESS2%3E%3C%2FIPADDRESS2%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20netmask%20%3CSUBNET%20mask%3D%22%22%3E%3C%2FSUBNET%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%8B%95%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%EF%BC%9A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20dhcp%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Esaveenv%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E9%96%93%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ping%20%24serverip%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EFM1%40DTSEC4%3C%2FSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ehost%20192.168.1.1%20is%20alive%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1171180108%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId--1171180108%22%20id%3D%22toc-hId--250581570%22%3ETFTP%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%20U-Boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3C%2FH3%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%3C%2FSPAN%3E%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%3A%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20probe%200%3A1%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20U-Boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%EF%BC%9A%3CBR%20%2F%3E%3COL%20style%3D%22list-style-type%3A%20lower-alpha%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20tftp%200xa0000000%20u-boot.bin%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Eprint%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3Dae84a%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3CLI%3EU-Boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%3A%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3Esf%20erase%200x1%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E00000%20%2B%24%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3Efil%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3Eesize%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%26amp%3B%26amp%3B%20sf%20write%200xa0000000%200x1%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E00000%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3Efilesize%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E0x100000%3C%2FSPAN%3E%20%E3%81%AFQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AEU-Boot%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3EPPA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%20%E2%80%93%20%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%2CLSDK%2018.09%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%82%8C%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342787%22%20target%3D%22_blank%22%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20background-color%3A%20%23ffffff%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%3A%26nbsp%3B%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ECPLD%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%26nbsp%3B%20altbank%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBoard%3A%20LS1046ARDB%2C%20boot%20from%20QSPI%20vBank%204%3C%2FSPAN%3E%3C%2FP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%20Ubuntu%20%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81LSDK%20Ubuntu%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%80%81USB%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20SCSI%20%E3%83%8F%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82U-Boot%20%E3%81%8C%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E8%A3%85%E7%BD%AE%E3%81%A7%20LSDK%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elsdk_linux_arm64_%20tiny.itb%3C%2FSPAN%3E%E3%81%8B%E3%82%89%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3ETinyDistro%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CH2%20id%3D%22toc-hId--1181683212%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%22%20id%3D%22toc-hId--1181683212%22%20id%3D%22toc-hId--261084674%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%202%EF%BC%9A%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%88SD%E3%80%81USB%E3%81%BE%E3%81%9F%E3%81%AF%20SATA%EF%BC%89%E4%B8%8A%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3C%2FH2%3E%3COL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3ELS1046ARDB%E3%82%92QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8CQSPI%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%20%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3EQSPI%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E3%81%AF%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW5%5B1%3A8%5D%20%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000100010%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3EQSPI%20NOR%20flash0%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bcpld%20reset%3C%2FSPAN%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBoard%3A%20LS1046ARDB%2C%20boot%20from%20QSPI%20vBank%200%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20rescan%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20start%3C%2FSPAN%3E%0A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20scan%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20info%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BB%BB%E6%84%8F%20%E2%80%93%20%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%200%3A3%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E6%83%85%E5%A0%B1%2F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20714826%20u-boot.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E1%20file(s)%2C%201%20dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%200%3A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%200%3A2%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%20modifiedtitle%3D%22true%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Els%3C%2FSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81U-Boot%20%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%A7%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Els%3C%2FSPAN%3E%20%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%80%81QSPI%20NOR%20flash0%20%E3%81%AE%20U-Boot%20%E3%81%8C%E3%81%9D%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%3C%2FSPAN%3E%0Als%20-%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%20(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E3%81%84%E6%96%B9%EF%BC%9A%0A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Els%20%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5Bdirectory%5D%5D%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%0A%20%3C%2FP%3E%3CP%3E-%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E7%A8%AE%E9%A1%9E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%5Binterface%5D%20%3C%2FSPAN%3E%20%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%5Bdev%5D%3C%2FSPAN%3E%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%5Bpart%5D%20%3C%2FSPAN%3E%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%5Bdirectory%5D%20%3C%2FSPAN%3E%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%20%E3%81%8C%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A50%E5%86%85%E3%81%AE%E8%A4%87%E5%90%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AE%E8%A4%87%E5%90%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342252%22%20target%3D%22_blank%22%3ELS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AE%E8%A4%87%E5%90%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FA%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%3C%2FSPAN%3E%3A%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20sf%20probe%200%3A1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89U-Boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%20a0000000%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A3%20a0000000%20u-boot.bin%3CBR%20%2F%3E52%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7714%2C826%E3%83%90%E3%82%A4%E3%83%88%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(13.1%20MiB%2Fs)%3CBR%20%2F%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3Dae84a%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%AD%E3%83%BC%E3%83%89%20USB%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%20a0000000%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20scsi%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%20a0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3EU-Boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3A%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%20%3D%26gt%3B%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%20sf%20erase%200x1%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%2000000%20%2B%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%20%26amp%3B%26amp%3B%20sf%20write%200xa0000000%200x1%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%2000000%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2011pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E0x100000%3C%2FSPAN%3E%E3%81%AFQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AEU-Boot%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%A7%E3%81%99%E3%80%82%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%3CA%20data-content-finding%3D%22Community%22%20href%3D%22http%3A%2F%2Fwww.%2Fdocs%2FDOC-342787%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%232989c5%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3EPPA%20%E2%80%93%20LSDK%2018.09%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%82%8C%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EQSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%3A%20%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ECPLD%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20altbank%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBoard%3A%20LS1046ARDB%2C%20boot%20from%20QSPI%20vBank%204%3C%2FSPAN%3E%3C%2FP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%20Ubuntu%20%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81LSDK%20Ubuntu%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%80%81USB%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20SCSI%20%E3%83%8F%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82U-Boot%20%E3%81%8C%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E8%A3%85%E7%BD%AE%E3%81%A7%20LSDK%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elsdk_linux_arm64_%20tiny.itb%3C%2FSPAN%3E%E3%81%8B%E3%82%89%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3ETinyDistro%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1127772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7U-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ESwati%E6%A7%98%E3%80%81%E3%81%93%E3%81%AE%E4%BB%B6%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%82JS%20Park%E3%81%95%E3%82%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%A8%E4%BC%BC%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A50%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE0x8000%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E6%B6%88%E5%8E%BB%EF%BC%8F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82QSPI%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%82%92%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%8F%E3%83%AD%E3%83%83%E3%82%AF%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%8CS25F512S%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE8%E3%81%A4%E3%81%AE4kB%E3%80%8C%E3%83%8F%E3%82%A4%E3%83%96%E3%83%AA%E3%83%83%E3%83%89%E3%80%8D%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%81%A7%E3%82%82%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AF%E5%81%B6%E7%84%B6%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%B9%B8%E3%81%84%E3%80%81CodeWarrior%20%E3%81%A8%20TAP%2F%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7U-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%8F%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%20U-Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A7%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%201%20%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E5%90%8C%E3%81%98%20U-Boot%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A7%20QSPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200%20%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A50%E3%81%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E5%86%8D%E7%8F%BE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7U-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%83%9A%E3%83%B3%E3%83%9E%E3%83%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ECode%20Worrier%E3%81%A7%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E9%80%9A%E5%B8%B8%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%81%8C%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%80%81Code%20Worrier%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%8A%B6%E6%B3%81%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7U-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJS%20Park%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82QSPI%20vBank0%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A0%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81LS1046A-RDB%E3%81%8CvBank0%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EvBank4%20%E3%81%A8%20SD%20%E3%81%AF%E3%80%81%E3%80%8EQorIQ%20LS1046A%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%E3%80%8F%E3%81%AB%E8%A9%B3%E7%B4%B0%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E3%83%9D%E3%82%B8%E3%82%B7%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EvBank0%20%E3%81%A8%20vBank4%20%E3%81%AF%E5%90%8C%E4%B8%80%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81vBank0%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7U-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81QSPI%20NOR%20flash1%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%80%8Ccpld%20reset%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20QSPI%20NOR%20flash0%20%E3%81%8B%E3%82%89%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%9F%E3%82%8A%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20QSPI%20NOR%20flash0%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%B2%E3%81%A8%E3%81%A4%E3%81%AE%E9%A0%85%E7%9B%AE%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81QSPI%20NOR%20flash0%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%AA%E3%81%8F%E3%81%A6%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CEM%3E%E3%80%8EQorIQ%20LS1046A%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%E3%80%8F%3C%2FEM%3E%E3%81%AB%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%88QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A50%E3%80%81QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%EF%BC%89%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A4%BA%E3%81%99%E8%A1%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A1%A8%E3%81%AF%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B312%E3%81%AB%E3%81%82%E3%82%8B%E3%80%8CLS1046ARDB%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%82%BD%E3%83%BC%E3%82%B9%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%BF%E3%82%A4%E3%83%88%E3%83%AB%E3%81%AE%E4%B8%AD%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E8%A8%AD%E5%AE%9A%E3%82%92%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8BCPLD%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%B8%80%E8%A6%A7%E3%81%AB%E3%81%97%E3%81%9F%E8%A1%A8%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7U-Boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E5%BE%8C%E3%80%81QSPI%20%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%B7%B1%E5%88%BB%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81QSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%231%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AF%E7%B5%82%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%231%20%E3%81%A8%E5%90%8C%E3%81%98%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%B6%AD%E6%8C%81%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20QSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%230%20%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E6%80%9D%E3%81%84%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E6%B6%88%E3%81%97%E3%81%A6%E6%9B%B8%E3%81%8D%E7%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%230%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82flash%231%E3%81%A8SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%81%AE%E3%81%BF%E8%B5%B7%E5%8B%95%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%231%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%230%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Eflash%230%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8Cflash%231%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%231%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%80%8Ccpld%20reset%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%230%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81flash%230%20%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AF%E8%B5%B7%E5%8B%95%E3%81%AB%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 03:31 AM
更新者:
