LS1028 Felix Switch Configuration
On successful probing of the DSA Felix switch, each available front panel switch port should have a network device interface attached with the swpX name format. The ip link show command uses the swpX@enoY name format to also indicate the associated master Ethernet interface for the DSA switch port, which corresponds to an internal ENETC interface, usually the eno2 (Port2) for the LS1028A SoC.
LS1028 Interface naming in Linux
Single port mode
Bridge mode
Comments
useful
%3CLINGO-SUB%20id%3D%22lingo-sub-1167348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1028%20Felix%20Switch%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1167348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3EOn%20successful%20probing%20of%20the%20DSA%20Felix%20switch%2C%20each%20available%20front%20panel%20switch%20port%20should%20have%20a%20network%20device%20interface%20attached%20with%20the%20swpX%20name%20format.%20The%20ip%20link%20show%20command%20uses%20the%20swpX%40enoY%20name%20format%20to%20also%20indicate%20the%20associated%20master%20Ethernet%20interface%20for%20the%20DSA%20switch%20port%2C%20which%20corresponds%20to%20an%20internal%20ENETC%20interface%2C%20usually%20the%20eno2%20(Port2)%20for%20the%20LS1028A%20SoC.%3C%2FP%3E%0A%3CP%3ELS1028%20Interface%20naming%20in%20Linux%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--1410713706%22%20id%3D%22toc-hId--499311784%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20line-height%3A%20173%25%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%22%3ESingle%20port%20mode%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CH2%20id%3D%22toc-hId-1076799127%22%20id%3D%22toc-hId-1988201049%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20line-height%3A%20173%25%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%22%3EBridge%20mode%3C%2FSPAN%3E%3C%2FH2%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1028%20Felix%20Switch%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Euseful%3C%2FP%3E%3C%2FLINGO-BODY%3E
100% helpful (4/4)
Version history
Last update:
‎10-14-2020 02:20 AM
Updated by:
