Mouse Device example
Description
This example implements a HID class device with mouse report descriptors. Mouse movement reports are sent to the host by the device when buttons or the joystick is pressed on the development board.
On the Embedded Artists LPCXpresso Rev A or B Baseboard this example will move the host PC's mouse cursor when the joystick is operated. Pressing the joystick down will create a mouse left click.
Compiler build configurations
The software that makes up this example is designed to run on many different development boards. Therefore the compiler must be configured to build an image that is targeted to the development board you are using. This section explains how to set these build configurations for each of the supported compilers.
LPCXpresso IDE
Configure projects
  right click on the BSP project in the project explorer window
  click Build Configurations->Set Active->(see configuration in table below)
  repeat these steps with the CDL, nxpUSBlib, and Example_MouseDevice
Configure MCU
  right click on the Example_MouseDevice project in the project explorer window
  click Properties->C/C++ Build->MCU settings->(see configuration in table below)
Configure the indexer
   click Window->Preferences->C/C++->Indexer->Use active build configuration
BSP
CDL
nxpUSBlib
Example_MouseDevice
MCU
LPC1850  / Hitex
LPC18xx_HITEX
LPC18xx
LPC18xx_Device
LPC18xx
LPC1850
LPC4330  / Xplorer
LPC4330_Xplorer
LPC18xx
LPC18xx_Device
LPC18xx
LPC4330
LPC4350  / Element14
LPC1435_ELEMENT14
LPC18xx
LPC18xx_Device
LPC18xx
LPC4350
LPC11U14 / LPCXpresso
LPC11Uxx_LPCXpressoRevB
LPC11Uxx
LPC11Uxx_Device
LPC11Uxx
LPC11U14
LPC11U14 / MCB1000
LPC11u14_MCB1000
LPC11Uxx
LPC11Uxx_Device
LPC11Uxx
LPC11U14
LPC1768  / MCB1700
LPC1768_MCB1700
LPC17xx
LPC17xx_Device
LPC17xx
LPC1768
LPC1768  / LPCXpresso
LPC17xx_LPCXpressoRevB
LPC17xx
LPC17xx_Device
LPC17xx
LPC1768
NOTE:
The LPC18xx CDL is used with boards that hold LPC43xx parts. This is done because the LPC43xx CDL is currently experimental. The LPC18xx USB library is used because both parts share the same controller.
Keil uVision 4 IDE
Configure a Batch Build
  click on Project->Batch Build...
  expand the BSP project to display a list of project targets
  select the project target by checking the appropriate checkbox (see target list in table below)
  repeat these steps with the CDL, nxpUSBlib_Device, and Example_MouseDevice
BSP
CDL
nxpUSBlib_Device
Example_MouseDevice
LPC1850  / Hitex
HITEX1800
LPC18xx
LPC18xx_Device
HITEX1800
LPC1768  / MCB1700
MCB1700
LPC17xx
LPC17xx_Device
MCB1700
LPC11U14 / MCB1000
MCB1000
LPC11Uxx
LPC11Uxx_Device
MCB1000
Board connections and configurations
LPC18xx_HITEX (LPC1850 Hitex Evaluation Board)  older A2 design
schematic ./BSP/schematics/HITEX_SCM_LPC1850EVA-A2-2.pdf
Connect the JTAG to the 20 pin receptacle marked X4 JTAG
Connect the type-B end of a USB cable to the receptacle marked X2. Plug the type-A end of this cable into a PC
LPC18xx_HITEX (LPC1850 Hitex Evaluation Board)  newer A4 design
schematic ./BSP/schematics/HITEX_Final_LPC1850EVA-A3.pdf
LPC4330_Xplorer (NGX Xplorer Evaluation Board with LPC4330)
Connect the JTAG to the 10 pin receptacle marked J2
Connect the micro-b end of a USB cable to the receptacle marked USB0. Plug the type-A end of this cable into a PC
LPC1435_ELEMENT14 (Element 14 gaming board with LPC4350)
Connect the JTAG to the 10 pin receptacle marked J6
Connect one end of a type-A to type-A USB cable to the receptacle marked USB0. Plug the other end of this cable into a PC
LPC11u14_MCB1000 (Keil MCB1000 development board)
schematic: ./BSP/schematics/mcb1000-schematics.pdf
Jumpers:
  J4 = 2-3      (UCON - PIO0_6 pulls D+ high)
  J2 = 1-2          (VDD  - core power)
  J5 not installed  (ISP  - ISP via COMM)
  J6 not installed  (RST  - ISP via COMM)
Connect the JTAG debugger to the 10 pin Cortex Debug connector labeled J3
Connect the type-B end of a USB cable to the type-B recepticle and the type-A end of the cable to the USB receptacle on a PC
Once the USB cable is connected to the board the following LEDs should be illuminated:
    Power
    All 8 LEDs in PIO2
LPC1768_MCB1700 (Keil MCB1700 development board)
schematic: ./BSP/schematics/mcb1700-schematics.pdf
Jumpers:
  E/U    = 1-2  (Ethernet/USB)
  UMODE  = 1-2  (USB Device Mode)
  D-     = Device
  D+     = Device
  VBUS   = 1-2
  VDDIO  = 1-2
  VDDREG = 1-2
Connect the JTAG debugger to the 20 pin JTAG or 10 pin Cortex Debug connector.
Connect the type-B end of a USB cable to the type-B recepticle labeled 'Device' and the type-A end of the cable to the USB receptacle on a PC. Once the USB cable is connected to the board the following LEDs should be illuminated:
    Power
    100MHz
    USC (LED indicates a USB soft connect from P2.9)
LPC11Uxx_LPCXpressoRevB (LPCXpresso LPC11Uxx on the LPCXpresso Rev B base board)
schematic: ./BSP/schematics/lpcxpresso.lpc11u14.schematic.pdf
Running this example on the LPCXpresso LPC11U14 can be done one of two ways:
1. LPCXpresso LPC11U14 stand-alone
      Connect the type-B end of a USB cable to the mini receptacle on the LPCXpresso board labeled J8 and the type-A end to the USB receptacle on a PC
2. LPCXpresso LPC11U14 plugged into the LPCXpresso base board Rev B
      Plug the LPCXpresso LPC11U14 board into the connector labeled J4 on a LPCXpresso base board Rev B
      Configure the base board according to the user's guide from Embedded Artists
      Connect the mini type-B end of a USB cable to the receptacle on the base board labeled X1 and the type-A end to the USB receptacle on a PC
          LED25  (vbus)
         LED26  (3.3v rail)
For both configurations the JTAG debugger is connected to the mini USB receptacle labeled J3 on the LPCXpresso LPC11U14 board
LPC17xx_LPCXpressoRevB (LPCXpresso LPC17xx on the LPCXpresso Rev B base board)
schematic: ./BSP/schematics/LPCXpressoLPC1769revB.pdf
Running this example on the LPCXpresso LPC1769 can be done one of two ways:
1. LPCXpresso LPC1769 stand-alone. Solder a type-B USB receptacle onto the board and wire it up. See included schematics for details. Connect the type-B end of a USB cable to the receptacle on the LPCXpresso board and the type-A end to the USB receptacle on a PC
2. LPCXpresso LPC1769 plugged into the LPCXpresso base board Rev B. Plug the LPCXpresso LPC1769 board into the connector labeled J4 on a LPCXpresso base board Rev B. Configure the base board according to the users guide from Embedded Artists. Connect the mini type-B end of a USB cable to the receptacle on the base board labeled X1 and the type-A end to the USB receptacle on a PC.
      LED25  (vbus)
      LED26  (3.3v rail)
For both configurations the JTAG debugger is connected to the mini USB receptacle labeled J3 on the LPCXpresso LPC1769 board.
PC configuration
Use a PC running Windows XP, Vista or 7 Connect the type-A end of the USB cable that is connected to the board into one of the USB receptacles on the PC
Build and debug the example
LPCXpresso IDE
In the project explorer window of the IDE right click on the Example_MouseDevice project and select Debug As->C/C++ MCU Application
In the main window of the IDE click Run->Resume to start running the application
Keil uVision 4 IDE
In the Batch Build window, select the project targets as described in Compiler Build Configurations and then click Build
In the main window of the IDE click Debug->Start/Stop Debug Session click Debug->Run
How this example runs and what to look for
When the example is run and the board is connected to a PC with a USB cable it will enumerate on the PC as a HID Mouse device. You should see the device appear in the "Device Manager" under "Mice". If you right click on HID  Device->Properties a window will appear called "HID Mouse Device Properties". If you select the "Details" tab you will see a "Properties" drop down, click on it and select "Hardware Ids". You should see the below entries for Vendor Id and Product Id.
HID\VID_1FC9&PID_2041&REV_0001
This information should match the data in the "Device Descriptor Structure" in the "Descriptors.c" file in the Example_MouseDevice project directory.
Press the joystick to move the mouse cursor on the PC desktop and push the buttons to cause mouse buttons to click.
%3CLINGO-SUB%20id%3D%22lingo-sub-1100164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-380486126%22%20id%3D%22toc-hId-1303176697%22%3E%3CSTRONG%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20helvetica%3B%22%3E%3CBIG%3E%E5%BD%A2%E5%AE%B9%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%9E%E3%82%A6%E3%82%B9%20%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E8%A8%98%E8%BF%B0%E5%AD%90%E3%82%92%E6%8C%81%E3%81%A4%20HID%20%E3%82%AF%E3%83%A9%E3%82%B9%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%AE%E5%8B%95%E3%81%8D%E3%81%AE%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B8%E3%83%A7%E3%82%A4%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%8C%E6%8A%BC%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EEmbedded%20Artists%20LPCXpresso%20Rev%20A%E3%81%BE%E3%81%9F%E3%81%AFB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A7%E3%82%A4%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E6%93%8D%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88PC%E3%81%AE%E3%83%9E%E3%82%A6%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%BD%E3%83%AB%E3%81%8C%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B8%E3%83%A7%E3%82%A4%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E4%B8%8B%E3%81%AB%E6%8A%BC%E3%81%99%E3%81%A8%E3%80%81%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%AE%E5%B7%A6%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--1426968337%22%20id%3D%22toc-hId--504277766%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FBIG%3E%20%3C%2FSPAN%3E%3C%2FH1%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-1060544496%22%20id%3D%22toc-hId-1983235067%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AF%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%99%E3%82%8B%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%90%84%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1751105970%22%20id%3D%22toc-hId--1621170755%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPCXpresso%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSTRONG%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%5BProject%20Explorer%5D%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%20BSP%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%80%8CBuild%20Configurations%E3%80%8D-%E3%80%8CSet%20Active-%26gt%3B%E3%80%8D%26gt%3B%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99(%E6%AC%A1%E3%81%AE%E8%A1%A8%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%20CDL%E3%80%81nxpUSBlib%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20CD%20%E3%81%A7%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99Example_MouseDevice%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSTRONG%3EMCU%20%E3%81%AE%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EProject%20Explorer%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7Example_MouseDevice%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EProperties-%26gt%3BC%2FC%2B%2B%20Build-%26gt%3BMCU%20settings-%26gt%3B%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99(%E4%B8%8B%E8%A1%A8%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSTRONG%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%82%AF%E3%82%B5%E3%83%BC%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%5BWindow%5D-%5B%26gt%3BPreferences%5D-%5B%26gt%3BC%2FC%2B%2B%5D-%5B%26gt%3BIndexer%5D-%5BUse%20active%20build%20configuration%5D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%228%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EBSP%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ECDL%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EnxpUSBlib%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EExample_MouseDevice%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCU%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1850%26nbsp%3B%20%2F%20Hitex%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_HITEX%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1850%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4330%26nbsp%3B%20%2F%20Xplorer%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4330_Xplorer%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4330%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4350%26nbsp%3B%20%2F%20Element14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1435_ELEMENT14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4350%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%20%2F%20LPCXpresso%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_LPCXpressoRevB%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%20%2F%20MCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11u14_MCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%20%2F%20MCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768_MCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%26nbsp%3B%20%2F%20LPCXpresso%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_LPCXpressoRevB%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%3A%3C%2FSPAN%3E%20LPC18xx%20CDL%E3%81%AF%E3%80%81LPC43xx%E3%83%91%E3%83%BC%E3%83%84%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81LPC43xx%20CDL%E3%81%8C%E7%8F%BE%E5%9C%A8%E5%AE%9F%E9%A8%93%E6%AE%B5%E9%9A%8E%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82LPC18xx%20USB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E9%83%A8%E5%93%81%E3%81%8C%E5%90%8C%E3%81%98%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--56348493%22%20id%3D%22toc-hId-866342078%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EKeil%20uVision%204%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSTRONG%3E%E3%83%90%E3%83%83%E3%83%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%5BProject-%26gt%3BBatch%20Build...%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EBSP%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%B1%95%E9%96%8B%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E4%B8%80%E8%A6%A7%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99(%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A1%A8%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%20CDL%E3%80%81nxpUSBlib_Device%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20Example_MouseDevice%20%E3%81%A7%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%228%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EBSP%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ECDL%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EnxpUSBlib_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EExample_MouseDevice%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1850%26nbsp%3B%20%2F%20Hitex%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EHITEX1800%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EHITEX1800%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%20%2F%20MCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%20%2F%20MCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_Device%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--66851597%22%20id%3D%22toc-hId-855838974%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%A8%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-623709877%22%20id%3D%22toc-hId-1546400448%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_HITEX(LPC1850%E3%83%8F%E3%82%A4%E3%83%86%E3%83%83%E3%82%AF%E3%82%B9%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89)%E5%8F%A4%E3%81%84A2%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%9B%9E%E8%B7%AF%E5%9B%B3%3C%2FSPAN%3E%20.%2FBSP%2Fschematics%2FHITEX_SCM_LPC1850EVA-A2-2.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJTAG%E3%82%92X4JTAG%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F20%E3%83%94%E3%83%B3%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97B%E5%81%B4%E3%82%92X2%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97A%E5%81%B4%E3%82%92PC%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--1183744586%22%20id%3D%22toc-hId--261054015%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_HITEX(LPC1850%20Hitex%20Evaluation%20Board)%E6%96%B0%E3%81%97%E3%81%84A4%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%9B%9E%E8%B7%AF%E5%9B%B3%3C%2FSPAN%3E%20.%2FBSP%2Fschematics%2FHITEX_Final_LPC1850EVA-A3.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1303768247%22%20id%3D%22toc-hId--2068508478%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4330_Xplorer(NGX%20Xplorer%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%80%81LPC4330%E4%BB%98%E3%81%8D)%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJTAG%20%E3%82%92%20J2%20%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%2010%20%E3%83%94%E3%83%B3%20%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AEmicro-b%E5%81%B4%E3%82%92USB0%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97A%E5%81%B4%E3%82%92PC%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--503686216%22%20id%3D%22toc-hId-419004355%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1435_ELEMENT14(Element%2014%E3%82%B2%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%9C%E3%83%BC%E3%83%89%E3%80%81LPC4350%E4%BB%98%E3%81%8D)%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJTAG%20%E3%82%92%20J6%20%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%2010%20%E3%83%94%E3%83%B3%20%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%20A%20%E3%81%8B%E3%82%89%E3%82%BF%E3%82%A4%E3%83%97%20A%20%E3%81%B8%E3%81%AE%20USB%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E4%B8%80%E6%96%B9%E3%81%AE%E7%AB%AF%E3%82%92%E3%80%81USB0%20%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%82%E3%81%86%E4%B8%80%E6%96%B9%E3%81%AE%E7%AB%AF%E3%82%92PC%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--637370940%22%20id%3D%22toc-hId-285319631%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11u14_MCB1000%20(Keil%20MCB1000%20%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89)%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%A6%82%E7%95%A5%E5%9B%B3%3A%20.%2FBSP%2Fschematics%2Fmcb1000-schematics.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJ4%20%3D%202-3%20(UCON%20-%20PIO0_6%20%E3%81%AF%20D%2B%20%E3%82%92%20High%20%E3%81%AB%E3%83%97%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJ2%20%3D%201-2%20(VDD%20-%20%E3%82%B3%E3%82%A2%E9%9B%BB%E6%BA%90)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJ5%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93(ISP%20-%20COM%E7%B5%8C%E7%94%B1%E3%81%AEISP)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJ6%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84(RST%20-%20COM%E7%B5%8C%E7%94%B1%E3%81%AEISP)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJTAG%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92J3%E3%81%A8%E3%81%84%E3%81%86%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AE%E4%BB%98%E3%81%84%E3%81%9F10%E3%83%94%E3%83%B3Cortex%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97B%E3%81%AE%E7%AB%AF%E3%82%92PC%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97B%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97A%E3%81%AE%E7%AB%AF%E3%82%92USB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AELED%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8A%9B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EPIO2%E3%81%AE8%E3%81%A4%E3%81%AELED%E3%81%99%E3%81%B9%E3%81%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1850141893%22%20id%3D%22toc-hId--1522134832%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768_MCB1700%20(Keil%20MCB1700%20%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89)%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%A6%82%E7%95%A5%E5%9B%B3%3A%20.%2FBSP%2Fschematics%2Fmcb1700-schematics.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EE%2FU%20%3D%201-2%20(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%2FUSB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUMODE%20%3D%201-2(USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ED-%20%3D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ED%2B%20%3D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EVBUS%20%3D%201-2%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EVDDIO%3D1-2%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EVDDREG%20%3D%201-2%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJTAG%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%9220%E3%83%94%E3%83%B3JTAG%E3%81%BE%E3%81%9F%E3%81%AF10%E3%83%94%E3%83%B3Cortex%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97B%E5%81%B4%E3%82%92%E3%80%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AE%E4%BB%98%E3%81%84%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%97B%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97A%E5%81%B4%E3%82%92PC%E3%81%AEUSB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AELED%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8A%9B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E100MHz%E3%81%AE%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSC(LED%E3%81%AFP2.9%E3%81%8B%E3%82%89%E3%81%AEUSB%E3%82%BD%E3%83%95%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-42687430%22%20id%3D%22toc-hId-965378001%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_LPCXpressoRevB(LPCXpresso%20Rev%20B%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AELPCXpresso%20LPC11Uxx)%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%A6%82%E7%95%A5%E5%9B%B3%3A%20.%2FBSP%2Fschematics%2Flpcxpresso.lpc11u14.schematic.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%82%92%20LPCXpresso%20LPC11U14%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E1.%20LPCXpresso%20LPC11U14%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97B%E5%81%B4%E3%82%92J8%E3%81%A8%E3%81%84%E3%81%86%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AE%E4%BB%98%E3%81%84%E3%81%9FLPCXpresso%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%9F%E3%83%8B%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%BF%E3%82%A4%E3%83%97A%E5%81%B4%E3%82%92PC%E3%81%AEUSB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E2.%20LPCXpresso%20LPC11U14%20LPCXpresso%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89RevB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPCXpresso%20LPC11U14%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92LPCXpresso%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89RevB%E3%81%AEJ4%E3%81%A8%E3%81%84%E3%81%86%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AE%E4%BB%98%E3%81%84%E3%81%9F%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EEmbedded%20Artists%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%BA%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%83%9F%E3%83%8B%E3%82%BF%E3%82%A4%E3%83%97B%E5%81%B4%E3%82%92X1%E3%81%A8%E3%83%A9%E3%83%99%E3%83%AB%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%9F%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%BF%E3%82%A4%E3%83%97A%E5%81%B4%E3%82%92PC%E3%81%AEUSB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AELED%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELED25(VBUS%E3%81%AE)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELED26(3.3v%E3%83%AC%E3%83%BC%E3%83%AB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E3%82%82%E3%80%81JTAG%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AFLPCXpresso%20LPC11U14%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEJ3%E3%81%A8%E3%81%84%E3%81%86%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AE%E4%BB%98%E3%81%84%E3%81%9F%E3%83%9F%E3%83%8BUSB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--1764767033%22%20id%3D%22toc-hId--842076462%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_LPCXpressoRevB%20(LPCXpresso%20Rev%20B%20%E3%83%99%E3%83%BC%E3%82%B9%20%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%20LPCXpresso%20LPC17xx)%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%A6%82%E7%95%A5%E5%9B%B3%3A%20.%2FBSP%2Fschematics%2FLPCXpressoLPC1769revB.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%82%92%20LPCXpresso%20LPC1769%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E1.%20LPCXpresso%20LPC1769%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E3%82%BF%E3%82%A4%E3%83%97B%20USB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%97%E3%80%81%E9%85%8D%E7%B7%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%98%E5%B1%9E%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97B%E5%81%B4%E3%82%92LPCXpresso%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%BF%E3%82%A4%E3%83%97A%E5%81%B4%E3%82%92PC%E3%81%AEUSB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E2.%20LPCXpresso%20LPC1769%20LPCXpresso%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89Rev%20B%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82LPCXpresso%20LPC1769%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92LPCXpresso%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89Rev%20B%E3%81%AEJ4%E3%81%A8%E3%81%84%E3%81%86%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AE%E4%BB%98%E3%81%84%E3%81%9F%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82Embedded%20Artists%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%83%9F%E3%83%8B%E3%82%BF%E3%82%A4%E3%83%97B%E5%81%B4%E3%82%92X1%E3%81%A8%E3%81%84%E3%81%86%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AE%E4%BB%98%E3%81%84%E3%81%9F%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%BF%E3%82%A4%E3%83%97A%E5%81%B4%E3%82%92PC%E3%81%AEUSB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AELED%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELED25(VBUS%E3%81%AE)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELED26(3.3v%E3%83%AC%E3%83%BC%E3%83%AB)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E3%82%82%E3%80%81JTAG%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AFLPCXpresso%20LPC1769%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEJ3%E3%81%A8%E3%81%84%E3%81%86%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AE%E4%BB%98%E3%81%84%E3%81%9F%E3%83%9F%E3%83%8BUSB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-593663081%22%20id%3D%22toc-hId-1516353652%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%3CBIG%3EPC%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EWindows%20XP%E3%80%81Vista%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF7%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BPC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97A%E5%81%B4%E3%82%92PC%E3%81%AEUSB%E3%83%AC%E3%82%BB%E3%83%97%E3%82%BF%E3%82%AF%E3%83%AB%E3%81%AE1%E3%81%A4%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--1213791382%22%20id%3D%22toc-hId--291100811%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1402804170%22%20id%3D%22toc-hId--1969472555%22%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPCXpresso%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EIDE%20%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%97%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%80%81Example_MouseDevice%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%80%81%5BAs-%26gt%3BC%2FC%2B%2B%20MCU%20Application%20%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%5D%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EIDE%E3%81%AE%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%BB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%80%81%E3%80%8C%E5%AE%9F%E8%A1%8C%E3%80%8D%E2%86%92%E3%80%8C%E5%86%8D%E9%96%8B%E3%80%8D%26gt%3B%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--404650293%22%20id%3D%22toc-hId-518040278%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EKeil%20uVision%204%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%80%8C%E3%83%90%E3%83%83%E3%83%81%E3%83%BB%E3%83%93%E3%83%AB%E3%83%89%E3%80%8D%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%80%81%E3%80%8C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%83%BB%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%E3%80%8D%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%BB%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%80%8C%E3%83%93%E3%83%AB%E3%83%89%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EIDE%E3%81%AE%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%BB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%80%81%E3%80%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%80%8D%26gt%3B%E3%80%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%BB%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E9%96%8B%E5%A7%8B%2F%E5%81%9C%E6%AD%A2%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%80%81%E3%80%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%80%8D%26gt%3B%E5%AE%9F%E8%A1%8C%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-1953779821%22%20id%3D%22toc-hId--1418496904%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%96%B9%E6%B3%95%E3%81%A8%E6%A4%9C%E7%B4%A2%E5%AF%BE%E8%B1%A1%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%20USB%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%20PC%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81PC%20%E4%B8%8A%E3%81%AB%20HID%20%E3%83%9E%E3%82%A6%E3%82%B9%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E5%88%97%E6%8C%99%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%80%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%80%8D%E3%81%AE%E3%80%8C%E3%83%9E%E3%82%A6%E3%82%B9%E3%80%8D%E3%81%AE%E4%B8%8B%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82HID%20Device-%26gt%3BProperties%E3%82%92%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8CHID%20Mouse%20Device%20Properties%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E8%A9%B3%E7%B4%B0%E3%80%8D%E3%82%BF%E3%83%96%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8C%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%80%8D%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%83%80%E3%82%A6%E3%83%B3%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%8C%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2ID%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%20ID%20%E3%81%A8%E8%A3%BD%E5%93%81%20ID%20%E3%81%AE%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EHID%5CVID_1FC9%26amp%3BPID_2041%26amp%3BREV_0001%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EHID%5CVID_1FC9%26amp%3BPID_2041%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E3%80%81%22Descriptors.c%22%20%E3%81%AE%20%22Device%20Descriptor%20Structure%22%20%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Example_MouseDevice%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E3%82%B8%E3%83%A7%E3%82%A4%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6PC%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E4%B8%8A%E3%81%AE%E3%83%9E%E3%82%A6%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%BD%E3%83%AB%E3%82%92%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-25-2016 02:23 PM
更新者:
