view the examples
view the examples
lpcware
Content originally posted in LPCWare by kalpak on Wed Nov 16 20:52:09 MST 2011
Not familiar with Eclipse, how does one view the examples provided with LPCXpresso?
thanks
lpcware
Content originally posted in LPCWare by TheFallGuy on Thu Nov 17 05:20:12 MST 2011
From the Quickstart panel, use Import projects
Under Project archives, press Browse
Browse to the Examples/NXP/LPC1000/LPC1300 (or whatever is your chip)
select one of the .zip files
and finish.
lpcware
Content originally posted in LPCWare by kalpak on Thu Nov 17 02:58:17 MST 2011
with the downloaded example code(\redstate\...) and again code from the web. For both zip files I get the message "no projects are found to import"
lpcware
Content originally posted in LPCWare by TheFallGuy on Thu Nov 17 00:43:59 MST 2011
did you read the getting started guide? it is explained in there.
