view the examples
view the examples
1,000 次查看
lpcware
Content originally posted in LPCWare by kalpak on Wed Nov 16 20:52:09 MST 2011
Not familiar with Eclipse, how does one view the examples provided with LPCXpresso?
thanks
993 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Thu Nov 17 05:20:12 MST 2011
From the Quickstart panel, use Import projects
Under Project archives, press Browse
Browse to the Examples/NXP/LPC1000/LPC1300 (or whatever is your chip)
select one of the .zip files
and finish.
993 次查看
lpcware
Content originally posted in LPCWare by kalpak on Thu Nov 17 02:58:17 MST 2011
with the downloaded example code(\redstate\...) and again code from the web. For both zip files I get the message "no projects are found to import"
993 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Thu Nov 17 00:43:59 MST 2011
did you read the getting started guide? it is explained in there.
