stdlib functions/Redlib variants
Content originally posted in LPCWare by wa7iut on Wed Jun 19 09:44:45 MST 2013
where can I find a list of functions implemented in each of the Redlib variants of stdlib
http://support.code-red-tech.com/CodeRedWiki/LibraryVariants?   I couldn't find more than this on the Code Red site after much looking.
Content originally posted in LPCWare by CodeRedSupport on Thu Jun 20 02:50:53 MST 2013
What functions are you trying to use, and what problems are you seeing?
The main restriction here will be malloc & co - you need to be using the Nohost or Semihost library variants in order to use the memory allocation functions. Otherwise you will see undefined reference errors, as per...
http://support.code-red-tech.com/CodeRedWiki/UndefinedReference
CodeRedSupport
