shortcut key to switch between open files
1,036 次查看
lpcware
Content originally posted in LPCWare by AndreiS on Wed May 13 06:23:00 MST 2015
    So, say I have three open files (tabs) in the IDE and I want to move/ switch between these three files...  Is there a shortcut key to do so?  Or will this require setting up some user defined keys.
Thank you,
2 回复数
1,030 次查看
lpcware
Content originally posted in LPCWare by AndreiS on Wed May 13 06:42:21 MST 2015
That will do it!  Thank you very much.
1,030 次查看
lpcware
Content originally posted in LPCWare by R2D2 on Wed May 13 06:28:05 MST 2015
Ctrl+F6  :quest:
