save on flash memory
Content originally posted in LPCWare by AndreSTB on Fri Jul 13 13:57:47 MST 2012
I'm starting to work with LPC4350, and I need to know how save on the external memory the boot program. Anybody have a document that explaning about this or know teach me.
I'm using the LPCXpresso to debug.
André Lessa
Content originally posted in LPCWare by AndreSTB on Thu Jul 19 05:32:24 MST 2012
I read the link said in previous post and helped me, but I never used a ARM with external memory and I need a document with more details (Tutorials). If anybody can help me I will be happy.
André Lessa
Content originally posted in LPCWare by CodeRedSupport on Tue Jul 17 10:37:59 MST 2012
Did you look at the FAQ that I previously pointed you to??
CodeRedSupport
Content originally posted in LPCWare by AndreSTB on Mon Jul 16 07:06:14 MST 2012
I need to know what I make to load the program in a external memory of the LPC4350 using the LPCXpresso? Becuse how the LPC4350 don't have a internaly memory flash I need to load in the external memory flash, then I did a bord and put a memory flash on channel SPIFI of the ARM, but I dont know how load the program in this memory.
André Lessa
Content originally posted in LPCWare by CodeRedSupport on Mon Jul 16 01:39:26 MST 2012
Sorry, I'm not sure I follow what you are asking. Can you explain in more detail?
I would also suggest that if you are working with LPC43xx, then you should take a look at the following FAQ:
http://support.code-red-tech.com/CodeRedWiki/LPC1850_4350_Support
CodeRed Support
