"Target reported errors"
1,479件の閲覧回数
Content originally posted in LPCWare by JohnR on Thu Apr 07 12:37:11 MST 2011
My colleaague testing a new homebuilt board in the field has encountered this error.
"Target reported errors" 15 target error from commit flash write
I think probably it is a wiring connection to the programming header but I would like to know what the message means.
Is there a list and definition of the error numbers anywhere?
Any help is appreciated,
JohnR
5 返答(返信)
1,407件の閲覧回数
Content originally posted in LPCWare by whitecoe on Thu Apr 07 23:13:23 MST 2011
Quote: JohnR
I had searched on "15 target error from commit flash write" but did not find it.
Try googling...
"target error from commit flash write"" site:knowledgebase.nxp.com
1,407件の閲覧回数
Content originally posted in LPCWare by JohnR on Thu Apr 07 14:44:56 MST 2011
Thanks Larryvc and CodeRed Support.
We'll try the suggestions and report back.
John.
1,407件の閲覧回数
Content originally posted in LPCWare by larryvc on Thu Apr 07 13:18:15 MST 2011
CodeRedSupport, maybe "15 target error from commit flash write" should be added to the wiki as well.
1,407件の閲覧回数
Content originally posted in LPCWare by CodeRedSupport on Thu Apr 07 13:11:17 MST 2011
The most common reason for these sort of errors is power. Flash programming increases the power consumption of the chip dramatically, and if your supply is not up to it, the flash programming will fail.
Also, suggest you take a look at this section of the FAQ:
http://support.code-red-tech.com/CodeRedWiki/CodeRedFAQ#DebugConnection
1,407件の閲覧回数
Content originally posted in LPCWare by larryvc on Thu Apr 07 13:02:08 MST 2011
John, follow this thread. I found it with a search of forum posts.
http://knowledgebase.nxp.com/showthread.php?t=1618&highlight=15+target+error+from+commit+flash+write
Hope it helps.
Larry
