"Build project" Always Builds Everything
859件の閲覧回数
lpcware
Content originally posted in LPCWare by Sal Ammoniac on Thu Nov 20 23:20:11 MST 2014
When I click the "Build project" icon (the hammer), it compiles all of my C and assembly files. If I then edit one of the C files and do another build, it goes and compiles everything again.
Why does it do this? I would expect that after I changed one of the C files after the first build the second build would just compile the file I changed, not all of the files again.
It's acting like "Build project" is really "Clean project + Build project".
Is there a configuration item that I have set incorrectly that's causing this behavior?
LPCXpresso 7.5.0
2 返答(返信)
848件の閲覧回数
lpcware
Content originally posted in LPCWare by Sal Ammoniac on Fri Nov 21 05:56:33 MST 2014
I am using Linux-style paths for include files. There's not a single '\' character in my entire project.
I'll try to post a subset of my project that still exhibits this issue...
848件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Nov 21 00:38:41 MST 2014
Normally, this is because you are using Windows-style paths for include files. You MUST use linux-style paths. i.e.
#include "dir/include.h"
and not
#include "dir\include.h"
If that does not solve your problem, exprt your project and post it her.
