please help wiring.h
nguga
please i am new here and i do not know exactly were to post this question , but i will try here .
i found a source code for a synthesizer on the net called  dsp-g1 , the source code is here:
The dsp-G1 Analog Modeling Synthesizer Source Code · GitHub
it uses the LPC810  , i download the adafruit code base for this chip that is here :
GitHub - microbuilder/LPC810_CodeBase: Open source code base for the ARM Cortex M0+ LPC810 family fr...
then imported to LPCxpresso .
then i replace the main.c with the source code of the dsp-g1 synth
then i Build , but LPCXpresso gives error...   that    wiring.h  and sct_fsm.h     are not found :smileysad:
please were do i can get that files ?
there are only 3 includes in the source code :
#include "wiring.h"
#include "LPC8xx.h"
#include "sct_fsm.h"
excuse my ignorance and my bad english  , Thanks in advance !
lpcxpresso_supp
You can find a copy of the post the author of this code posted (originally on the old LPCware site) at : The dsp-G1 analog modeling synthesizer. And the author appears to have a site at: dsp-G1 | DIY Synthesizer
I suggest you try contacting him for the headers he uses.
LPCXpresso Support
