new project resources are not compiled
lpcware
Content originally posted in LPCWare by askar on Wed Mar 19 07:11:05 MST 2014
Hi everybody,
I created a new project and add some folders and files into project,
then for using lwip resource from lpcopen, i inseted the lwip directory files containing
src and in subdirectories int project. i did this from import wizard for this.
after making the project, there were some link errors in lwip header files,
after sometimes checking i found out that none of lwip sources are compiled,
is there any switch for putting some sources out of compile process.
the exclude from project switch in lpcxpresso for above folder was off.
best regards,
lpcware
Content originally posted in LPCWare by LabRat on Wed Mar 19 07:35:28 MST 2014
Excluded?
http://www.lpcware.com/content/forum/lpcxpresso-linked-file-not-compiling
No Source Folder?
See #1 of http://www.lpcware.com/content/forum/header-source-file-related-question
