lpc4357 and jtag
lpc4357 and jtag
6,920 次查看
lpcware
Content originally posted in LPCWare by salamlora1 on Sat Mar 22 03:52:51 MST 2014
I have a open43xxe2 + core43xxe2 and want to work with jtag but i can’t set the jtag for download and debugging in the lpcexpresso
I can do all of this work in the IAR easily but the lpcexpresso are a little confusing me can anyone can help me? :((
8 回复数
6,894 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Sat Apr 05 05:51:19 MST 2014
Please explain what you problem is? Are you trying to use J-Link? If so, read the faq at:
http://www.segger.com/nxp-lpcxpresso.html
6,894 次查看
lpcware
Content originally posted in LPCWare by salamlora1 on Fri Apr 04 23:11:09 MST 2014
I’m again
I find a way to run the debugger
1-Build the project
2 – Download the bin file with another program (most of the programmers take an checksum error wen want to download the lpcexpresso bin file)
3 – Run the lpcexpresso debugger
(I have IAR and Keil both of them can program and debug with jtag please give me a solution)
6,894 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Mon Mar 24 12:24:19 MST 2014
It really doesn't matter how you answer the question, but I would suggest you press No (and check the Remember my decision box).
6,894 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Mar 24 11:35:16 MST 2014
Please note LPCXpresso support of this GDB server solution is the responsibility of Segger.
LPCXpresso-Support
6,894 次查看
lpcware
Content originally posted in LPCWare by salamlora1 on Mon Mar 24 09:16:47 MST 2014
Hi thx for your help
I do all of things says in that address
But I have problem!
I can’t run the jtag ?
The messages are in the picture
6,894 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Sun Mar 23 08:05:45 MST 2014
If you are using LPCXpresso v7, you can now use jlink from segger. See this FAQ from segger
6,894 次查看
lpcware
Content originally posted in LPCWare by salamlora1 on Sun Mar 23 06:14:15 MST 2014
[color=#f30]really ?!!!!!!![/color]
:O  :((
PatrickT
Beginner
Date of registration: Jan 22nd 2014
1
Thursday, January 30th 2014, 5:58pm
How do I setup LPCXpresso for use with my J-Link?How do I setup LPCXpresso for use with my J-Link? I thought LPCXpresso worked through GDB and I could simply use SEGGER's GDB server. When trying this I get
No compatible emulator available
Do I have to change the port within LPCXpresso somehow?  Go to the top of the page
SEGGER - Alex
Super Moderator
Date of registration: Dec 18th 2007
2
Thursday, February 6th 2014, 7:46pm
Hi Patrick,
Quoted I thought LPCXpresso worked through GDB and I could simply use SEGGER's GDB server
Unfortunately this is not the case. LPCXpresso currently uses a more or less proprietary interface which is based on GDB in general but does not allow generic/vanilla GDB connections to third party GDBServers.
So currently, you cannot use J-Link with LPCXpresso due to lack of support from the IDE side.
- Alex
address : http://www.forum.segger.com/index.php?page=Thread&threadID=1728
6,894 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Sat Mar 22 07:23:59 MST 2014
There are a number of FAQs on working with LPC43 parts with LPCXpresso - with a good starting point being:
http://www.lpcware.com/content/faq/lpcxpresso/lpc18-lpc43-support
If you need further help, please clarify exactly what you are trying to do.
LPCXpresso Support
