lpc1114 reinvoke isp - problem ?
Content originally posted in LPCWare by plebi on Thu Sep 01 00:38:25 MST 2011
As I understand uC LPC114 can be set in bootloader mode using external pin (and reset) or using programm method showed in example 'invokeisp"
When Im use external pin and I can use "flash magic" to program uC, I can set up connection using console (?, Synchtronized etc.).  Everything works well. But when i use this exaple I cant communicate with bootloader anyway.
How to check that this example works well ?
