lpc1114 not detected
1,052件の閲覧回数
lpcware
Content originally posted in LPCWare by rajvignesh on Mon Aug 16 11:12:42 MST 2010
i have plugged in lpc1114 embedded artists board to my pc. it does not recignize the board. pls help
2 返答(返信)
1,036件の閲覧回数
lpcware
Content originally posted in LPCWare by whitecoe on Wed Aug 18 09:58:38 MST 2010
Quote: rajvignesh
i have plugged in lpc1114 to my system that has both lpc xpresso and red suite 3. it is not detected. i have connected it through usb. pls help
A few details would probably increase the chance of you getting some help!!:D
For example
- What OS are you using?
- What tools versions are you using?
- What error messages do you see in what circumstances?
I assume that you get some form of error when you select "Debug" in the quickstart panel within the IDE. You may well find that doing a google for [I]"error_message[/I] site:knowledgebase.nxp.com" provides you with a few clues.
1,036件の閲覧回数
lpcware
Content originally posted in LPCWare by rajvignesh on Wed Aug 18 08:45:58 MST 2010
