lpc1114 not detected
1,056 次查看
lpcware
Content originally posted in LPCWare by rajvignesh on Mon Aug 16 11:12:42 MST 2010
i have plugged in lpc1114 embedded artists board to my pc. it does not recignize the board. pls help
1,040 次查看
lpcware
Content originally posted in LPCWare by whitecoe on Wed Aug 18 09:58:38 MST 2010
Quote: rajvignesh
i have plugged in lpc1114 to my system that has both lpc xpresso and red suite 3. it is not detected. i have connected it through usb. pls help
A few details would probably increase the chance of you getting some help!!:D
For example
- What OS are you using?
- What tools versions are you using?
- What error messages do you see in what circumstances?
I assume that you get some form of error when you select "Debug" in the quickstart panel within the IDE. You may well find that doing a google for [I]"error_message[/I] site:knowledgebase.nxp.com" provides you with a few clues.
1,040 次查看
lpcware
Content originally posted in LPCWare by rajvignesh on Wed Aug 18 08:45:58 MST 2010
