internal E2PROM
internal E2PROM
Content originally posted in LPCWare by cesimkaol on Mon Nov 14 06:37:55 MST 2011
I did not know there is a internal E2PROM in lpcxpresso 1769 ,when I examine getting started document I saw internal E2PROM which is connected to P0.19 and P0.20 , so can I use it with I2C .I have never used I2C before so ı want to try this E2PROM.
Dear Zero ,I am waiting your answer , thank you man!
Content originally posted in LPCWare by cesimkaol on Mon Nov 14 08:07:46 MST 2011
#define Master_Buffer_BUFSIZE35
#define Slave_Buffer_BUFSIZE32
Could you explain , why buffer size allocated like that?
Content originally posted in LPCWare by cesimkaol on Mon Nov 14 07:26:07 MST 2011
why did you write NO , I2C sample codes writed for this 24LC64. so there is a E2PROM...ofcourse , Its an options that solder it out ,it could be little weird for who never used it before .
Content originally posted in LPCWare by Ex-Zero on Mon Nov 14 06:56:45 MST 2011
No, schematic shows an E2PROM :eek:
http://www.embeddedartists.com/sites/default/files/docs/schematics/LPCXpressoLPC1769revB.pdf
Anyway, i always solder them out and solder in a nice new FRAM :rolleyes:
