bootloader flash magic
1,323 次查看
Content originally posted in LPCWare by tmltml51 on Thu Dec 13 12:27:51 MST 2012
I using flash magic to load the hex file format program to the board lpc1769.when I load programs exsamples UART0 to the board is not problems ,but then  when I load other files, the error message.
my problem?
solution?
1,255 次查看
Content originally posted in LPCWare by cfb on Fri Dec 14 00:17:33 MST 2012
Go to:
http://www.flashmagictool.com/resources.html
Follow the instructions in App Note 4 "What to do if ISP does not work"
1,255 次查看
Content originally posted in LPCWare by tmltml51 on Thu Dec 13 18:33:30 MST 2012
Quote: cfb
What is the error message that you get?
  Thanks for the reply
this error message
1,255 次查看
Content originally posted in LPCWare by cfb on Thu Dec 13 13:18:35 MST 2012
