Wizard for LPC11D14/302????
623 次查看
Content originally posted in LPCWare by sipel_tp on Tue Sep 11 08:22:15 MST 2012
Hi everybody!!! I have a doubt. I'm using LPCXpresso 4.23 build 292. I need to create a new project using a LPC11D14/302. But it seems that the wizard doesn't support it. Any suggestions?? Thank you for your replies.
617 次查看
Content originally posted in LPCWare by CodeRedSupport on Wed Sep 12 01:38:51 MST 2012
We will be adding LPC11D14/302 explicitly in the next release. But from the tools point of view, this part is just an LPC1114/302 - so for now you can use this part instead within the wizard.
CodeRedSupport
