Why different .bin file generated in lpcXpresso compared to redsuite??
rajani_sureja33
We are using lpcXpresso v8.2.2 and Redsuite v5.1.0.
Please advice on this asap that will really helpful.
lpcxpresso_supp
You've provided no useful details. If the same project build options are used, my guess is these IDEs use different tool versions. So, the code generators differ in some way.
Thanks and regards,
LPCXpresso Support
