What is 'Step Filters' feature?
Content originally posted in LPCWare by Maru_t on Tue May 18 00:06:22 MST 2010
I could start testing LPCXpresso1114_blinky on XP Home Edition Version 2002 Service PAck 3.
LPCXpresso's IDE is working well.
I have questions.
What is 'Step Filters'? I'd like to have a simple explanation of this feature.
What should be the expected working of the debugger if I once selected 'Use Step Filter'?
Although I will continue to search for it in Help documents, Thank you for answers!
M_t
Content originally posted in LPCWare by Maru_t on Tue May 18 01:49:42 MST 2010
Hello CodeRedSupport,
Your Explanaion is helpful enough for me.
Thank you!
M_t
Content originally posted in LPCWare by CodeRedSupport on Tue May 18 00:56:48 MST 2010
Step filters are a java specific debug function within Eclipse. When debugging Java, the step filters button works in a similar way Step Into, but it allows control over which methods it will step into.
You can ignore Step filters for the C debugging provided by the LPCXpresso IDE.
CodeRedSupport
