Watch / Chance Variables AND PWM Output just 100 edges
458 次查看
lpcware
Content originally posted in LPCWare by manu1910 on Thu Feb 18 00:12:56 MST 2016
At first im sorry for my bad englisch...
i have to program an Stepper Motor Driver with LPC 1759.
Enable and Direction is no problem. I have to take the clock signal from PWM Pin 2.0.
I get the PWM clock and can so adjust my frequency. However, I do not know how confining the flanks. I have to drive different length sequences. For example only 15 flanks or 3200 flanks. After the sequence i have to turn of the PWM pin.
You know that i mean...???
And an other Question:
Thanks for your help
Manuel
0 回复数
