LPCXpresso v5.2.6 released
lpcware
Content originally posted in LPCWare by CodeRedSupport on Wed Jul 10 08:38:11 MST 2013
LPCXpresso v5.2.6 has been released. This is a minor update, with changes including:
* Fix failure to initialise data section in multi-core slave application.
* Fix Redlib problem with realloc.
* LPC11U/11E/11A new project wizards now provide support for rom divide.
* New project wizards now generate Code Read Protect (CRP) variable into separate source file, rather than in main.c.
You can download from:
http://lpcxpresso.code-red-tech.com/
Instructions for updating can be found at:
http://support.code-red-tech.com/CodeRedWiki/UpdatingNewMinorVersion
CodeRedSupport
