Using LPCXpresso and Red Suite 4
954 次查看
lpcware
Content originally posted in LPCWare by guillaumeL on Mon Jan 09 09:07:59 MST 2012
  I'm developping a code with Red Suite 4 and I expect to buy the LPC1769 lpcxpresso board (http://www.embeddedartists.com/products/lpcxpresso/lpc1769_xpr.php). Do you think I will work, can I debug my program with this evaluation board?
945 次查看
lpcware
Content originally posted in LPCWare by guillaumeL on Mon Jan 09 09:34:42 MST 2012
Ok thanks for your help
945 次查看
lpcware
Content originally posted in LPCWare by rmteo on Mon Jan 09 09:27:42 MST 2012
Red Suite 4 directly supports the LPC-Link hardware (on the LPCXpresso LPC1769) so you can use it without any any limitations.
945 次查看
lpcware
Content originally posted in LPCWare by Ex-Zero on Mon Jan 09 09:16:27 MST 2012
Yes, it's a LPCXpresso1769. So you can even use the free 128k 'LPCXpresso 4' version :)
