Unsed pin configuration
811 次查看
Content originally posted in LPCWare by LynnF on Tue Mar 16 13:45:59 MST 2010
I am looking for your opinion, educated or a guess.
On unused and unconnected pins on the LPCxpresso board how would you believe they should be configured to minimize transient interference? Presently they are configured as pulled up inputs. (the default startup setting)
Would you change this, say maybe configure as an output without any any pullup or pulldown? Or...what do you think.
802 次查看
Content originally posted in LPCWare by LynnF on Tue Mar 16 16:01:51 MST 2010
802 次查看
Content originally posted in LPCWare by leon_heller on Tue Mar 16 14:24:35 MST 2010
Unused pins are usually configured as outputs.
