Static -binary- libraries for LPCXpresso
Content originally posted in LPCWare by elektronist on Wed Apr 29 01:20:57 MST 2015
How can we create, distribute and use binary only libraries for LPCXpresso, like i2c_display_lib?
http://www.lpcware.com/content/blog/lcd-driver-pcf2119-sample-code
Content originally posted in LPCWare by elektronist on Wed Apr 29 03:44:07 MST 2015
Thanks for quick response.
A tiny add: Right click on the library in Project Explorer doesn't show Binary Utilities menu entry. Instead right clicks on liblibraryname.a in Debug and Release do.
Content originally posted in LPCWare by lpcxpresso-support on Wed Apr 29 01:40:56 MST 2015
In the first place, read:
http://www.lpcware.com/content/faq/lpcxpresso/creating-linking-library-projects
Once you have a working library archive, you may wish to strip the debug information from it before distribution. This can be done in one of the following ways:
[list]
  [*]Right click on the library in Project Explorer and select Binary utilities->Strip debug symbols
  [*]Run the following command from a command prompt (or as a post build step):
[list]
  [*]arm-none-eabi-objcopy -g liblibraryname.a
[/list]
[/list]
LPCXpresso Support
