Content originally posted in LPCWare by Mondo90 on Fri Aug 22 08:23:43 MST 2014
starblue, I update my first post and now you can see my ADCInit function where I configure input pins. Anyway it is example code so it should work just fine and eveything should be configured well ;/
UPDATE! Problem solved, these strange output results comes from no ground reference. My mistake.
Thanks for help.
