Regarding lpc1788 CAN
686 次查看
lpcware
Content originally posted in LPCWare by badri89 on Fri Apr 05 04:50:02 MST 2013
Hi all,
I am thinking of using CAN of lpc1788 which is used in my board.
I got confused regarding a few points:
1. Is the isolator is inbuilt in lpc1788, so that I can directly take out CANH,CANL without any isolator IC?
2. What cables should be used for CAN communication.Can I use any cable for CAN?
c
And also please do some pointers for beginners in CAN.
Thanks!
665 次查看
lpcware
Content originally posted in LPCWare by tha on Fri Apr 05 15:13:52 MST 2013
There is a nice CAN primer from the MCB1700.
http://www.keil.com/download/files/canprimer_v2.pdf
