Red Probe+ power sequence
857 次查看
Content originally posted in LPCWare by jdurand on Wed Apr 11 22:47:46 MST 2012
I just purchased a Red Probe+ and can't find any information on power sequencing.  For example, are the following cases ok:
Red Probe+ powered off, target power on.
Red Probe+ powered on, target power off.
I've used some debug pods in the past that cared about the power, but most don't.  I just don't want to damage anything.
Also, from their connector pinout page it appears this does NOT supply power to targets, is that correct?
849 次查看
Content originally posted in LPCWare by jdurand on Thu Apr 12 15:09:35 MST 2012
Thanks, I always like to check after being surprised with other probes.
849 次查看
Content originally posted in LPCWare by CodeRedSupport on Wed Apr 11 23:41:03 MST 2012
Red Probe+ is tolerant of powering in any order.
Red Probe+ does not supply target power.
