Red Probe Family not found.
1,364 次查看
lpcware
Content originally posted in LPCWare by Prajakta_26 on Fri Jun 26 22:37:28 MST 2015
I am using Red Probe+ debugger with LPC2138. I am using this from last more than 5 months. but, now (today) when I am using it, debugger could not connect to my board. Its give error. error  file is attached here.
I am using LPCXpresso V7.6.2.
Please suggest me solution.
Thanks in advance
1 回复
1,344 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Fri Jun 26 23:00:43 MST 2015
Does it appear in windows device manager? If not then check cables and try different USB port. Otherwise it has probably gone bad.
