Project rename
Project rename
Content originally posted in LPCWare by giovanniquaglia on Tue Feb 15 08:36:47 MST 2011
There is an easy way to rename a project ?
Content originally posted in LPCWare by giovanniquaglia on Tue Feb 15 09:16:02 MST 2011
Thank you.
Content originally posted in LPCWare by CodeRedSupport on Tue Feb 15 08:52:15 MST 2011
Select the project in the Project Explorer view, right click, and select "Rename".
You might also want to read this FAQ:
http://support.code-red-tech.com/CodeRedWiki/CopyingExampleProjects
CodeRedSupport
