Problem getting while doing example projects
Content originally posted in LPCWare by angiey on Tue Mar 19 22:42:21 MST 2013
Hi all!!
I'm very new to LPCXpresso software,so i'm now trying to do some sample examples given,so i tried running led blinky project and i build & debugged the project,according to the output we should get"LED2 must flash at regular intervals",but for now i'm getting only LED2 'ON' in the target side of my board, so what is the problem why it is not blinking kindly help.
Thanks in advance.
Angiey:confused:
Content originally posted in LPCWare by angiey on Wed Mar 20 04:41:40 MST 2013
I have not changed the sample code, i just imported it from example projects and build it, kindly find the attached sample code.
Thank you.
Angiey
Content originally posted in LPCWare by serge on Wed Mar 20 00:41:01 MST 2013
Without having a look at your code we can only guess. Have you changed anything in the sample code?
So the best thing to do is export your blinky project and post it here so we can have a look at it.
