Printf -> UART3
Printf -> UART3
lpcware
Content originally posted in LPCWare by Albert on Sat Mar 26 05:48:27 MST 2011
Hi all,
Somebody know how use the printf function to send data for the UART3 port? or for other function?
Thanks.
lpcware
Content originally posted in LPCWare by Albert on Sat Mar 26 06:57:47 MST 2011
Hi Zero,
I was using the code:
unsigned char UART_BUFFER[16];
unsigned char qt;
qt=sprintf(UART_BUFFER,"tes %u",32);
UART0_Sendchar(UART_BUFFER,qt);
Your solution is smarter.
lpcware
Content originally posted in LPCWare by Ex-Zero on Sat Mar 26 06:11:27 MST 2011
Are we still talking about LPC17xx?
1. #include <stdio.h>
2. Setup UARTx
3. Include this function:
//set for printf
int __write (int iFileHandle, char *pcBuffer, unsigned char iLength)
 unsigned int i;
 for (i = 0; i<iLength; i++)
  UART0_Sendchar(pcBuffer);    //print character
 return iLength;
so printf is using UART0_Sendchar..
See:
http://support.code-red-tech.com/CodeRedWiki/UartPrintf
