More variants?
More variants?
1,481件の閲覧回数
lpcware
Content originally posted in LPCWare by OXO on Mon May 09 08:10:32 MST 2011
Are there plans to expand the range of processors supported by LPCXpresso?
I specifically need LPC2387
2 返答(返信)
1,475件の閲覧回数
lpcware
Content originally posted in LPCWare by OXO on Mon May 09 09:37:46 MST 2011
THose products are too expensive. I'll go elsewhere..
1,475件の閲覧回数
lpcware
Content originally posted in LPCWare by CodeRedSupport on Mon May 09 08:45:08 MST 2011
There are no plans to expand the number of ARM7 based parts supported by the LPCXpresso IDE. If you require support for ARM7 based parts such as LPC2387, you will need to look at one of the variants of our Red Suite product....
http://support.code-red-tech.com/CodeRedWiki/ProductOverview
CodeRedSupport.
