Make errors
Make errors
2,400件の閲覧回数
Content originally posted in LPCWare by jdurand on Wed Jan 30 17:39:04 MST 2013
I've suddenly started getting make errors that I haven't seen before.  It also goes ahead and links, downloads, and enters debug on the target.  ??
make: *** [src/Firmware_Update.o] Error 1                 C/C++ Problem
make: *** No rule to make target `clean'.                 C/C++ Problem
I haven't changed the Firmware_Update file in some time.  Also haven't had any problems with CLEAN before.
LPCXpresso v5.0.14, Ubuntu Linux.
10 返答(返信)
2,354件の閲覧回数
Content originally posted in LPCWare by jdurand on Thu Jan 31 16:33:15 MST 2013
Odd, that worked.
So, Problem view -> Select All -> Delete
Build yields no errors.
I just did a CLEAN and BUILD ALL and no errors.
I didn't even know you COULD delete errors, don't they self-clear when you start a new build????
2,354件の閲覧回数
Content originally posted in LPCWare by TheFallGuy on Thu Jan 31 16:03:34 MST 2013
Where? In the Problem view? Right click and delete/clear the errors and thencleanand rebuild.
2,354件の閲覧回数
Content originally posted in LPCWare by Ex-Zero on Thu Jan 31 15:59:15 MST 2013
Funny messages :eek: Did you try Index->Rebuild already?[FONT=Courier New][SIZE=1]
[/SIZE][/FONT]
2,354件の閲覧回数
Content originally posted in LPCWare by jdurand on Thu Jan 31 15:52:44 MST 2013
See the VERY first message.  I'm getting two MAKE errors BUT it still finishes building.
To put it another way...receiving ERROR messages bothers me, especially when I don't know why.
2,354件の閲覧回数
Content originally posted in LPCWare by TheFallGuy on Thu Jan 31 15:03:33 MST 2013
So it built correctly. What is your problem?
2,354件の閲覧回数
Content originally posted in LPCWare by jdurand on Thu Jan 31 14:40:00 MST 2013
third "half" (didn't all fit in the first two posts):
Building target: PVP_2012.axf
Invoking: MCU Linker
arm-none-eabi-gcc -nostdlib   -L"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/Debug"   -Xlinker -Map="PVP_2012.map" -Xlinker --gc-sections -Xlinker   --allow-multiple-definition -mcpu=cortex-m0 -mthumb -T   "PVP_2012_Debug.ld" -o "PVP_2012.axf"    ./src/FreeRTOS/portable/MemMang/heap_1.o    ./src/FreeRTOS/portable/GCC/ARM_CM0/port.o  ./src/FreeRTOS/croutine.o   ./src/FreeRTOS/list.o ./src/FreeRTOS/queue.o ./src/FreeRTOS/tasks.o   ./src/FreeRTOS/timers.o  ./src/Firmware_Update.o ./src/Front_Panel.o   ./src/High_Voltage.o ./src/Host.o ./src/LCD.o ./src/SPI.o   ./src/aeabi_romdiv_patch.o ./src/cr_startup_lpc12xx_FreeRTOS.o   ./src/initialize.o ./src/main.o ./src/misc.o   -lCMSISv2p00_LPC12xx
Finished building target: PVP_2012.axf
make --no-print-directory post-build
Performing post-build steps
arm-none-eabi-size "PVP_2012.axf"; # arm-none-eabi-objcopy -O binary   "PVP_2012.axf" "PVP_2012.bin" ;  checksum -p LPC1226_301 -d   "PVP_2012.bin";
   text       data        bss        dec        hex    filename
  34000        244       6096      40340       9d94    PVP_2012.axf
13:29:11 Build Finished (took 25s.643ms)
2,354件の閲覧回数
Content originally posted in LPCWare by jdurand on Thu Jan 31 14:39:14 MST 2013
second half:
Building file: ../src/Front_Panel.c
../src/cr_startup_lpc12xx_FreeRTOS.c:412:23: warning: variable 'stacked_r1' set but not used [-Wunused-but-set-variable]
Invoking: MCU C Compiler
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/Front_Panel.d"  -MT"src/Front_Panel.d" -o "src/Front_Panel.o" "../src/Front_Panel.c"
../src/cr_startup_lpc12xx_FreeRTOS.c:411:23: warning: variable 'stacked_r0' set but not used [-Wunused-but-set-variable]
Finished building: ../src/Front_Panel.c
Building file: ../src/High_Voltage.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/High_Voltage.d"  -MT"src/High_Voltage.d" -o "src/High_Voltage.o" "../src/High_Voltage.c"
Finished building: ../src/High_Voltage.c
Building file: ../src/Host.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/Host.d"  -MT"src/Host.d" -o "src/Host.o" "../src/Host.c"
Finished building: ../src/Host.c
Building file: ../src/LCD.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/LCD.d"  -MT"src/LCD.d" -o "src/LCD.o" "../src/LCD.c"
Finished building: ../src/LCD.c
Building file: ../src/SPI.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/SPI.d"  -MT"src/SPI.d" -o "src/SPI.o" "../src/SPI.c"
Finished building: ../src/SPI.c
Building file: ../src/aeabi_romdiv_patch.s
Invoking: MCU Assembler
arm-none-eabi-gcc -c -x assembler-with-cpp -D__REDLIB__ -DDEBUG  -D__CODE_RED -D__USE_ROMDIVIDE -g3 -mcpu=cortex-m0 -mthumb -o  "src/aeabi_romdiv_patch.o" "../src/aeabi_romdiv_patch.s"
Finished building: ../src/aeabi_romdiv_patch.s
Building file: ../src/cr_startup_lpc12xx_FreeRTOS.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -Os -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP  -MF"src/cr_startup_lpc12xx_FreeRTOS.d"  -MT"src/cr_startup_lpc12xx_FreeRTOS.d" -o  "src/cr_startup_lpc12xx_FreeRTOS.o"  "../src/cr_startup_lpc12xx_FreeRTOS.c"
Finished building: ../src/cr_startup_lpc12xx_FreeRTOS.c
Building file: ../src/initialize.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/initialize.d"  -MT"src/initialize.d" -o "src/initialize.o" "../src/initialize.c"
Finished building: ../src/initialize.c
Building file: ../src/main.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/main.d"  -MT"src/main.d" -o "src/main.o" "../src/main.c"
Finished building: ../src/main.c
Building file: ../src/misc.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED  -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE  -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0"   -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang"  -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections  -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/misc.d"  -MT"src/misc.d" -o "src/misc.o" "../src/misc.c"
Finished building: ../src/misc.c
2,354件の閲覧回数
Content originally posted in LPCWare by jdurand on Thu Jan 31 14:38:32 MST 2013
First half (message too big for a single post):
13:28:46 **** Build of configuration Debug for project PVP_2012 ****
make all
Building file: ../src/FreeRTOS/portable/MemMang/heap_1.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/FreeRTOS/portable/MemMang/heap_1.d" -MT"src/FreeRTOS/portable/MemMang/heap_1.d" -o "src/FreeRTOS/portable/MemMang/heap_1.o" "../src/FreeRTOS/portable/MemMang/heap_1.c"
Finished building: ../src/FreeRTOS/portable/MemMang/heap_1.c
Building file: ../src/FreeRTOS/portable/GCC/ARM_CM0/port.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/FreeRTOS/portable/GCC/ARM_CM0/port.d" -MT"src/FreeRTOS/portable/GCC/ARM_CM0/port.d" -o "src/FreeRTOS/portable/GCC/ARM_CM0/port.o" "../src/FreeRTOS/portable/GCC/ARM_CM0/port.c"
Finished building: ../src/FreeRTOS/portable/GCC/ARM_CM0/port.c
../src/cr_startup_lpc12xx_FreeRTOS.c: In function 'pop_registers_from_fault_stack':
../src/cr_startup_lpc12xx_FreeRTOS.c:418:23: warning: variable 'stacked_psr' set but not used [-Wunused-but-set-variable]
Building file: ../src/FreeRTOS/croutine.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/FreeRTOS/croutine.d" -MT"src/FreeRTOS/croutine.d" -o "src/FreeRTOS/croutine.o" "../src/FreeRTOS/croutine.c"
Finished building: ../src/FreeRTOS/croutine.c
Building file: ../src/FreeRTOS/list.c
../src/cr_startup_lpc12xx_FreeRTOS.c:417:23: warning: variable 'stacked_pc' set but not used [-Wunused-but-set-variable]
../src/cr_startup_lpc12xx_FreeRTOS.c:416:23: warning: variable 'stacked_lr' set but not used [-Wunused-but-set-variable]
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/FreeRTOS/list.d" -MT"src/FreeRTOS/list.d" -o "src/FreeRTOS/list.o" "../src/FreeRTOS/list.c"
../src/cr_startup_lpc12xx_FreeRTOS.c:415:23: warning: variable 'stacked_r12' set but not used [-Wunused-but-set-variable]
Finished building: ../src/FreeRTOS/list.c
Building file: ../src/FreeRTOS/queue.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/FreeRTOS/queue.d" -MT"src/FreeRTOS/queue.d" -o "src/FreeRTOS/queue.o" "../src/FreeRTOS/queue.c"
../src/cr_startup_lpc12xx_FreeRTOS.c:414:23: warning: variable 'stacked_r3' set but not used [-Wunused-but-set-variable]
Finished building: ../src/FreeRTOS/queue.c
Building file: ../src/FreeRTOS/tasks.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/FreeRTOS/tasks.d" -MT"src/FreeRTOS/tasks.d" -o "src/FreeRTOS/tasks.o" "../src/FreeRTOS/tasks.c"
Finished building: ../src/FreeRTOS/tasks.c
Building file: ../src/FreeRTOS/timers.c
../src/cr_startup_lpc12xx_FreeRTOS.c:413:23: warning: variable 'stacked_r2' set but not used [-Wunused-but-set-variable]
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/FreeRTOS/timers.d" -MT"src/FreeRTOS/timers.d" -o "src/FreeRTOS/timers.o" "../src/FreeRTOS/timers.c"
Finished building: ../src/FreeRTOS/timers.c
Building file: ../src/Firmware_Update.c
arm-none-eabi-gcc -D__REDLIB__ -DDEBUG -D__CODE_RED -D__USE_CMSIS=CMSISv2p00_LPC12xx -D__DISABLE_WATCHDOG -D__USE_ROMDIVIDE -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/CMSISv2p00_LPC12xx/inc" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/include" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/GCC/ARM_CM0" -I"/home/jerry/Shared/Clients/Products/PVP-2012/firmware/PVP_workspace/PVP_2012/src/FreeRTOS/portable/MemMang" -O0 -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -MMD -MP -MF"src/Firmware_Update.d" -MT"src/Firmware_Update.d" -o "src/Firmware_Update.o" "../src/Firmware_Update.c"
Finished building: ../src/Firmware_Update.c
2,354件の閲覧回数
Content originally posted in LPCWare by TheFallGuy on Thu Jan 31 14:27:07 MST 2013
Post all the output from the build console so we can see what the problems are. Do a clean followed by a normal build by pressing the appropriate buttons in the quickstart panel.
2,354件の閲覧回数
Content originally posted in LPCWare by jdurand on Thu Jan 31 14:02:31 MST 2013
Additional information:
I tried this project on two other Ubuntu systems with the same result.
I forgot to mention this is Ubuntu 12.04 LTS on all systems.  LPCXpresso Full license.
