Lpc1768 + ssd1963
Lpc1768 + ssd1963
1,823 次查看
Content originally posted in LPCWare by Kilohercas on Wed Oct 12 23:19:36 MST 2011
Hello everybody.
Just get touchscreen+LCD and now having hard time to connecting it to LPCXpresso dev board
This one:
http://www.embeddedartists.com/products/lpcxpresso/lpc1769_xpr.php
And lcd is this one: (SSD1963+SD+[FONT=Arial][SIZE=3][COLOR=Black]TSC2046[/COLOR][/SIZE][/FONT])
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110754124873
Does any one have a tip or code for initialize this LCD ?
that would help a lot
Thank you
5 回复数
1,565 次查看
Content originally posted in LPCWare by rmteo on Mon Oct 17 07:26:11 MST 2011
Quote: igorsk
Did you use built-in forum search? See the sticky on top of the topic list.
No I did not.  I used the search box at the top right of the screen.
Anyway, I did a search for TFT LCD and got this - hope it helps the OP:
http://www.google.com/search?q=TFT+LCD+site%3Aknowledgebase.nxp.com&hl=en&num=10&lr=&ft=i&cr=&safe=i...
1,565 次查看
Content originally posted in LPCWare by igorsk on Mon Oct 17 05:30:51 MST 2011
Quote: rmteo
Too bad. I did a search for TFT (and TFT LCD) and got zero hits.  Looks like one here is working with these.
1,565 次查看
Content originally posted in LPCWare by Kilohercas on Sun Oct 16 12:37:23 MST 2011
mbed has code for SSD1963 but syntax and library are different from LPCXpresso IDE, bummer :(
http://mbed.org/users/andrewcrussell/programs/Ovation_Controller_1/lsh1sc/docs/
maybe some on has a tip how to fix it for LPCXpresso ide ?
1,565 次查看
Content originally posted in LPCWare by rmteo on Sun Oct 16 09:34:37 MST 2011
1,565 次查看
Content originally posted in LPCWare by Kilohercas on Fri Oct 14 09:10:16 MST 2011
it's always fun to get 0 help then starting with microcontrollers ;)
