LPCxpresso 1114 - problem with examples
1,804 次查看
lpcware
Content originally posted in LPCWare by RWM on Wed May 05 15:02:52 MST 2010
Hi, I have problem with LPCXpresso1114_systick_twinkle example. When I try to debug it, error is reported:
Target reports license restriction
License type is License type: FULL
Debug limit: 128k
When I tried second time, following error was reported:
Target reported errors:
Reason:
License restriction: Flash image too large for this license
I think this example is smaller than 128k, LPC1114 has only 32k of Flash. LPCXpresso1114_blinky example works. I use LPCXpresso 3.3.4. Any idea?
8 回复数
1,789 次查看
lpcware
Content originally posted in LPCWare by lki99 on Sun May 16 15:30:33 MST 2010
New 'beta' version of  LPCxpresso solves my problem too. Thanks to Code Red Support.
1,789 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun May 16 11:58:28 MST 2010
Please contact Code Red Support via this page:
http://www.code-red-tech.com/support.php
1,789 次查看
lpcware
Content originally posted in LPCWare by lki99 on Sun May 16 05:46:52 MST 2010
Hello, CodeRedSupport
In "Display License Type" menu message is:
License type: FULL
Debug Limit 128k
When I try to debug Example "LPCXpresso1343_consoleprint", I get error message:
License restriction: Flash image too large for this license.
When I try to use command line flash loader, I have this output:
crt_emu_lpc11_13_nxp.exe -wire=winusb -flash-load=c:\1.bin -pLPC1343
Ni: LPCXpresso Debug Driver v2.0 (Apr  8 2010 14:57:58)
Nc: Looked for chip XML file in C:/nxp/lpcxpresso_3.3/bin/LPC1343.xml
Nc: Looked for vendor directory XML file in C:/nxp/lpcxpresso_3.3/bin/nxp_directory.xml
Nc: Found generic directory XML file in C:/nxp/lpcxpresso_3.3/bin/crt_directory.xml
Nc: NXP: LPC1343  Part ID: 3D00002B
Wt: License check failure (CheckLicense)
Cr:f Restricted - unregistered license, download limit of 8K
Et:53: License does not permit flash operations from command line
Where is the problem?
1,789 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun May 16 01:48:50 MST 2010
The beta is not generally available. It was a special release specifically for RWM.
Can you explain exactly what your problem is, as it is likely that it is a different problem to that reported by RWM.
1,789 次查看
lpcware
Content originally posted in LPCWare by lki99 on Sat May 15 14:32:26 MST 2010
Quote: RWM
Problem solved by Code Red Support - new (beta) version of LPCxpresso.
And where is this new beta version - I have the same problem with my    LPCxpresso 1343?
1,789 次查看
lpcware
Content originally posted in LPCWare by RWM on Wed May 12 04:57:34 MST 2010
1,789 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Thu May 06 09:59:50 MST 2010
RWM,
It might be faster if you can contact Code Red support through our  support web page.
We'd like to send a license diagnostic for you to run. It produces one  or two output files you'll need to return. These files do not contain  personal information if you're concerned.
CodeRedSupport
1,789 次查看
lpcware
Content originally posted in LPCWare by Luis Digital on Wed May 05 18:21:13 MST 2010
Debug limit: 128k
Reason:
Not your fault, is a  manufacturing fault (a feature, say some):
[LIST]
[*][B]Version 3.3 license restriction, image size?[/B]
[*][B]Invalid Activation Code[/B]
[*][B]v3.3.4 error message, License restriction:[/B]
[/LIST]
