LPCXpresso v5.2.4 released
550 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Wed May 01 02:05:00 MST 2013
LPCXpresso v5.2.4 has been released. Changes in this release include:
* Fixed problem in managed linker script that affects projects with 'old-style' startup code
* Fixed missing images in Red State Getting Started PDF
* Fixed memory configuration editor
* Added 'Refresh' button to MCU selection to refresh internal caches
[INDENT]Allows easy fixing of missing flash driver problem seen by some customers with LPCXpresso 5.2.2.
For more details see http://support.code-red-tech.com/CodeRedWiki/FlashDriverNotFound522[/INDENT]
* Fixed problem with the LPC11/12/13 flash driver for 1KB SRAM parts overflowing available SRAM.
* Fixed potential mass erase problem with the LPC17xx/407x_8x flash drivers for parts with less than 512KB flash
You can download from:
http://lpcxpresso.code-red-tech.com/
Instructions for updating can be found at:
http://support.code-red-tech.com/CodeRedWiki/UpdatingNewMinorVersion
CodeRedSupport
0 回复数
