LPCXpresso project
LPCXpresso project
2,063 次查看
lpcware
Content originally posted in LPCWare by 12345 on Tue Sep 06 02:53:18 MST 2011
Can I know what are the below files for?
      1).cproject
      2).project
      3)xxx Release.launch
       if copy the whole project, except the above files,
       will it affect the project? Tks
2,053 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Tue Sep 06 12:53:25 MST 2011
The .cproject and .project files are the configuration files for your project. Deleting them is not advised!
The.launch file is a debug launch configuration file (i.e. it contains details of how the tools will connect to your debug target). You can safely delete this and the tools will then automatically recreate a default launch configuration next time you debug.
Depending upon what you are actually trying to do here, you might find the following FAQs of interest....
http://support.code-red-tech.com/CodeRedWiki/CopyingExampleProjects
http://support.code-red-tech.com/CodeRedWiki/ImportExport
CodeRedSupport
