LPCXpresso Software Knowledgebase
1,292 次查看
Content originally posted in LPCWare by CodeRedSupport on Fri Jan 22 05:06:20 MST 2010
Hi all,
We thought it was worth highlighting to new users that there is a knowledgebase containing answers to many commonly asked questions on using the LPCXpresso tools available at:
http://lpcxpresso.code-red-tech.com/LPCXpresso/softwareknowledgebase
We hope you find the information this contains useful. We will continue to add new entries and extend the existing ones going forward.
CodeRedSupport
1,253 次查看
Content originally posted in LPCWare by CodeRedSupport on Thu Oct 14 09:33:49 MST 2010
We have recently centralised all our FAQs onto the main Code Red support site at:
http://www.code-red-tech.com/CodeRedWiki
Although the LPCXpresso Knowledgebase is still currently live, it is no longer being updated, and all existing entries now point to the equivalent FAQ on the main Code Red support site.
1,253 次查看
Content originally posted in LPCWare by Douglas on Tue May 11 14:16:33 MST 2010
There are many interesting subjects covered in red-code knowledge base, but I would like to see a good document on the Eclipse version used in the Xpresso IDE.
There are tons of Eclipse documents on the net, but I did not find one that matches the Xpresso IDE.
There is also a short description on the IDE Help -> Help Contents -> Workbench User Guide. Where can I find something more detailed about the "cut-down" version of the Eclipse used here ?
1,253 次查看
Content originally posted in LPCWare by annodomini2 on Fri Jan 22 06:52:45 MST 2010
Would suggest you make this sticky so people can find it.
