LPCXpresso Manual
LPCXpresso Manual
lpcware
Content originally posted in LPCWare by blasiis on Mon Mar 22 01:31:22 MST 2010
Do you exist a pdf version of lpcxpresso manual for workbench and c directive ?
lpcware
Content originally posted in LPCWare by CodeRedSupport on Wed Mar 24 03:01:29 MST 2010
The LPCXpresso Getting Started is available in PDF form from:
http://ics.nxp.com/support/documents/microcontrollers/pdf/lpcxpresso.getting.started.pdf
[a version can also be found in the install directory of lpcxpresso].
I am afraid that this is the only PDF based documentation on the IDE.  General information on the workbench and on the gnu build tools can be found via the IDE menu...
[B]Help -> Help Contents -> Workbench User Guide[/B]
[B]Help -> Help Contents -> Product Documentation[/B]
We also have a number of hints and tips on using the IDE at:
http://lpcxpresso.code-red-tech.com/LPCXpresso/softwareknowledgebase
In addition, if you have specific usage questions, please feel free to post them in the forum.
CodeRedSupport
